180D warning lights
/ 180D warning lights #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
My vintage 180D has 4 lights on the dash. The top 2 are green and for the turn signals. The bottom 2 are red warning lights, probably oil pressure and non-charging. Trouble is, they are not marked and my lower light is on. I can not find my owners manual. Can anyone help me? Thanks.
/ 180D warning lights #2
A picture may help.
Thanks for the replies. I diagnosed the problem by starting the engine and pulling the wire off the oil pressure sender. The light went out. So the problem is either the sender or oil pump. Senders are about $15 and easy to replace. The pump $250. I guess that I will start with the sender.
By the way, I did find my manual. The dash pictured did not resemble the dash on my tractor and although it had lights it did not indicate which light was for oil pressure.
/ 180D warning lights #6
There was only one dash used on the MT180. You might want to do some research to confirm what model it is. I just sold a haed gasket set to someone & he said it was too big. Further research determined it was an imported shibaura & not a Ford tractor. In my 27 years of dealing with Japanese tractor parts, I have come across mislabeling many times.
/ 180D warning lights #7
There was only one dash used on the MT180. You might want to do some research to confirm what model it is. I just sold a head gasket set to someone & he said it was too big. Further research determined it was an imported shibaura & not a Ford tractor. In my 27 years of dealing with Japanese tractor parts, I have come across mislabeling many times.
And it is not getting any better either. The VN recons are so badly mislabeled its not easy to know what a person really has. Makes part searching very difficult for everyone.
/ 180D warning lights #8
Post some images of your dash and the tractor. We can help you sort things out. (y)
2003 GMC C4500 Crew Cab Dump (A62613)
2003 GMC C4500...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
