18.4x24 equivalent
/ 18.4x24 equivalent #1
Doubledeuce
Newfoundland
None
Hey all.
Just purchased a tym t654psc and am looking to get a set of chains for the rear to help.with traction while snowclearing.
Tractor has 18.4/24 R4 tires on the rear, but am unable to find chains for that exact size. Am looking at trygg smt flexi chains, and see a set for 16.9/26 tires. It appears this size tire is roughly the same diameter as 18.4/24.
Do you think they are close enough that I could easily make them fit?
/ 18.4x24 equivalent #2
I think the 16.9 chains would be too narrow to sit down and tighten up on your 18.4's.
Or a set of 420/85-24's would be very close,
Thanks! I'm clueless about chains. I will look into the 420/85/24 chains
/ 18.4x24 equivalent #4
On the Trygg or Aquillian style of chains your width is more important then the length of the chains. A too long set can be shortened easily (kind of), but if they are too narrow for your tires they will not sit down and fasten up snuggly.
The 18.4 in your tire corresponds with the 420 in the metric tire sizes, with the 85 corresponds to the older standard sidewall height. And the 24 being your rim diameter.
The TYRGG SMT's are a very good chain.
Edited; the 420's are not the correct width to match up with an 18.4, needs to be 460/480 to match up in width.
Lou
Just curious....
wouldn't 18.9/24 tires have a width of 18.9x25.4 = 480mm?
Wouldn't the 420/85/24 be 420÷25.4=16.5 inches?
Just seems to me that the 420/85/24 chains would be too skinny, by about 2.5 inches?
/ 18.4x24 equivalent #8
I see 2 at 480 and one at 420. I would take the 420 as a misprint.
Google "tractor tire conversion charts" and pick a chart that isn't confusing.
/ 18.4x24 equivalent #9
I do believe you are correct it looks like the 420 would be an error in the chart.
Just going by the math 18.4 inch comes to 467.36 mm, so a 460 would be close and a 480 would also be close.
/ 18.4x24 equivalent #10
From TRYGG's web site;
/ 18.4x24 equivalent #11
This is confusing.
3 different widths listed for 18.4 inch tires.
Just trying to get this right before I order a set. Too expensive for me to order only to find they don't fit.
Have you called the manufacturer to ask ?
/ 18.4x24 equivalent #12
I replaced my 17.5LR24 with a 460/70LR24 tire, so the 480 is correct.
Not yet, no. For a couple of reasons. Firstly, I wanted to get the feedback of people on this forum first. I figured there must be someone here who has run into this before. Secondly, I'm a couple hundred miles offshore on an oil platform working nightshifts. It's alot easier to post online than to make phone calls.
/ 18.4x24 equivalent #14
(y)
WHIRLPOOL REFRIGERATOR/FREEZER W/ICE MAKER (A64281)
WHIRLPOOL...
Peterbilt 377 Semi-Truck (A63689)
Peterbilt 377...
2012 Volkswagen Passat Sedan (A61574)
2012 Volkswagen...
2017 Chevrolet Malibu Sedan. (A61574)
2017 Chevrolet...
(5) 12' CARPETED BOAT GUIDES (A64280)
(5) 12' CARPETED...
2025 82in Rock Bucket Skid Steer Attachment (A61572)
2025 82in Rock...
