1782 with kubota
/ 1782 with kubota #1
kellytheaker
Rockwood Ontario
110 TLB
Red fused wire to solenoid is popping fuse , is this a starter problem or is there something else causing the problem, i cannot start due to the problem . The fuse is fine to use for glow plugs but is blown as soon as the key is turned . thanks in advance
/ 1782 with kubota #2
Try disconnecting the wire on the solenoid. If the fuse doesn't blow the solenoid is probably bad. Are you sure the fuse is the correct rating?
Bob B.
/ 1782 with kubota #3
Also check for short circuit to frame on positive cable from the solenoid to the starter motor.
