1782 with kubota
   / 1782 with kubota #1
kellytheaker
Rockwood Ontario
110 TLB
Red fused wire to solenoid is popping fuse , is this a starter problem or is there something else causing the problem, i cannot start due to the problem . The fuse is fine to use for glow plugs but is blown as soon as the key is turned . thanks in advance
   / 1782 with kubota #2
Try disconnecting the wire on the solenoid. If the fuse doesn't blow the solenoid is probably bad. Are you sure the fuse is the correct rating?
Bob B.
   / 1782 with kubota #3
Also check for short circuit to frame on positive cable from the solenoid to the starter motor.
2018 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2018 GENIE GS-1930...
2005 Ford E350 XLT SD Passenger Van (A53117)
2005 Ford E350 XLT...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
