1754 with sensor or control unit issue
/ 1754 with sensor or control unit issue #21
Biodegraded,
Since you had success initiating a manual region on your 1700 tractor, do you think you can initiate a regen whenever you want, even if there isn’t maximum bars showing?
Or do you think you need to have the “regen needed” light on?
I still can’t force a regen. I tried this morning with my tractor at operating temp. No luck.
Perhaps it needs to be at idle, cold, neutral and parking brake light lite?
/ 1754 with sensor or control unit issue #22
The following must be true:
Parking brake on
Must be in neutral
Engine must be running
and it sounds like the Manual DPF Switch must be held down for 7-10 seconds which sure seems like a long time.
How many bars are showing on your soot meter?
/ 1754 with sensor or control unit issue #23
4 bars show. Been at 4 bars for a while now.
/ 1754 with sensor or control unit issue #24
My manual says "Manual regeneration is necessary when the soot level gauge shows 7 or 8 bars" maybe that is also a requirement.
How many hours on your 1754?
My 1736 seems to regen every 50-60 hours. Definitely running higher rpm's extends the hours between.
/ 1754 with sensor or control unit issue #25
I have 583 hours on the tractor.
I was wondering if I needed more bars before it would let me do a forced regen. Seems like it used to do a regen automatically when I had 4 bars but perhaps it takes more. Maybe when the 5th bar appears, it will do an auto regen after it gets to operating temp?
There are 8 spaces for bars but only 4 are black.
/ 1754 with sensor or control unit issue #26
I just tried to force a region. No luck.
Parking brake lamp lit, in neutral, idling, almost cold engine. (I used it this morning, so it cooled down some.)
/ 1754 with sensor or control unit issue #27
Ya I'm guessing you need more bars for a forced manual regen.
If I can remember on my 1736 it never has automatically regened at 4 bars, seems like it has always been 5 bars when it does it.
/ 1754 with sensor or control unit issue #28
I guess I’ll just have to wait it out! Thanks to all who provided advice and experiences.
IRanch REV High End Scooter (A60463)
IRanch REV High...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
Iranch IRET13 (A60463)
Giyi GY-STB47 QA Telescopic Boom (A60463)
Giyi GY-STB47 QA...
2016 Terex RL4 S/A Towable Light Tower (A60352)
2016 Terex RL4 S/A...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
