1754 with sensor or control unit issue
/ 1754 with sensor or control unit issue #21
Biodegraded,
Since you had success initiating a manual region on your 1700 tractor, do you think you can initiate a regen whenever you want, even if there isn’t maximum bars showing?
Or do you think you need to have the “regen needed” light on?
I still can’t force a regen. I tried this morning with my tractor at operating temp. No luck.
Perhaps it needs to be at idle, cold, neutral and parking brake light lite?
/ 1754 with sensor or control unit issue #22
The following must be true:
Parking brake on
Must be in neutral
Engine must be running
and it sounds like the Manual DPF Switch must be held down for 7-10 seconds which sure seems like a long time.
How many bars are showing on your soot meter?
/ 1754 with sensor or control unit issue #23
4 bars show. Been at 4 bars for a while now.
/ 1754 with sensor or control unit issue #24
My manual says "Manual regeneration is necessary when the soot level gauge shows 7 or 8 bars" maybe that is also a requirement.
How many hours on your 1754?
My 1736 seems to regen every 50-60 hours. Definitely running higher rpm's extends the hours between.
/ 1754 with sensor or control unit issue #25
I have 583 hours on the tractor.
I was wondering if I needed more bars before it would let me do a forced regen. Seems like it used to do a regen automatically when I had 4 bars but perhaps it takes more. Maybe when the 5th bar appears, it will do an auto regen after it gets to operating temp?
There are 8 spaces for bars but only 4 are black.
/ 1754 with sensor or control unit issue #26
I just tried to force a region. No luck.
Parking brake lamp lit, in neutral, idling, almost cold engine. (I used it this morning, so it cooled down some.)
/ 1754 with sensor or control unit issue #27
Ya I'm guessing you need more bars for a forced manual regen.
If I can remember on my 1736 it never has automatically regened at 4 bars, seems like it has always been 5 bars when it does it.
/ 1754 with sensor or control unit issue #28
I guess I’ll just have to wait it out! Thanks to all who provided advice and experiences.
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2018 Hitachi ZX300LC-6N Hydraulic Excavator (A66734)
2018 Hitachi...
2018 MACK LR GARBAGE TRUCK (A66091)
2018 MACK LR...
NISSAN 35 MAST FORKLIFT (A67714)
NISSAN 35 MAST...
CULVERTS / PIPE STAND (A68842)
CULVERTS / PIPE...
2006 MACK CHN613 (INOPERABLE) (A67714)
2006 MACK CHN613...
