1720d 4wd problem
/ 1720d 4wd problem #1
gskeeters
Every time I remove the shaft and replace the ball bearings the 4wd works for a short time then stops. I remove shaft and replace ball bearings and same thing. Any ideas on what needs replaced? Is there any type of modification I can make to prevent this or do I need to replace something?
Thanks
/ 1720d 4wd problem #2
Assuming you are talking about the balls on the drive shaft coming out. If so, have you checked making sure all components showing on this nice Hoye drawing are in place? Spring, etc. that holds tension. 4WD INTERNAL ^: Yanmar Tractor Parts
/ 1720d 4wd problem
Thanks, I'll go through and insure everything is in place. Is it possible that the spring is weak and allowing it to slip causing the balls to fall out?
/ 1720d 4wd problem #4
I can't answer that. Seems it could be possible. Do all your components look ok, no rust or evident wear spots?
/ 1720d 4wd problem
It's all there and I can't see anything that looks worn beyond normal. Pulled the shaft, cleaned it all up. Installed new metal balls packed in grease and was very careful to insure they stayed in place when I reinstalled. Took out and began moving some gravel I had delivered for my drive. Worked about a half hour and when I was backing up in some deep gravel.... It quit working again. Can spin the shaft so the ball bearings have obviously fell out again.
Frustrating and thinking maybe the yokes either on the shaft or front diff are worn out. The rear bearings appear to be in tact each time I pull the shaft... It's the front:forward one that are out
/ 1720d 4wd problem
Awesome link. Thanks. I thing from the looks of the spline that mine is also showing wear from bearing spin. I can do some welding and grinding and fix it for sure. Thanks for the help!!
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
MIXING BUCKET (A62613)
2023 Bobcat T64 (A64126)
2023 Bobcat T64...
