1720 Won't Start
   / 1720 Won't Start #1
kb9trc
Indiana
ford 1720
Out of gear, pto off, clutch depressed. Battery and connections check good, I suppose that a bad cell would show on charger. I get the usual lights when key is turned on but glow plug lights don't show and it won't turn over.
Any ideas would be greatly appreciated.
Thanks!
   / 1720 Won't Start #2
what happens when you turn the key? any noise at all?
   / 1720 Won't Start #3
There may be a safety switch that is broken or a wire to it may have come off. This happened to me on my 1715, the wire to the safety switch for the clutch had come off of the connector and I experienced the same symptoms you are.
   / 1720 Won't Start
Thanks for the reply. No lights when I try the glow plugs and no sounds when I try the starter. I'm going to change the ground cable today, its the old "mesh" type ground.
   / 1720 Won't Start
Thanks for the reply. I'll try to track down the safety switches this afternoon.
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
2015 Ford F-750 Stellar 10628 10,000lb. Mechanics Crane Service Truck (A56858)
2015 Ford F-750...
SAKAI SV414D SMOOTH DRUM ROLLER (A52709)
SAKAI SV414D...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
