1720 Won't Start
   / 1720 Won't Start #1
kb9trc
Indiana
ford 1720
Out of gear, pto off, clutch depressed. Battery and connections check good, I suppose that a bad cell would show on charger. I get the usual lights when key is turned on but glow plug lights don't show and it won't turn over.
Any ideas would be greatly appreciated.
Thanks!
   / 1720 Won't Start #2
what happens when you turn the key? any noise at all?
   / 1720 Won't Start #3
There may be a safety switch that is broken or a wire to it may have come off. This happened to me on my 1715, the wire to the safety switch for the clutch had come off of the connector and I experienced the same symptoms you are.
   / 1720 Won't Start
Thanks for the reply. No lights when I try the glow plugs and no sounds when I try the starter. I'm going to change the ground cable today, its the old "mesh" type ground.
   / 1720 Won't Start
Thanks for the reply. I'll try to track down the safety switches this afternoon.
JOHN DEERE 333G SKID STEER (A52709)
JOHN DEERE 333G...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
Tank Only (A59076)
Tank Only (A59076)
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2016 BOBCAT T550 SKID STEER (A52709)
2016 BOBCAT T550...
