1710 hydraulic fluid
   / 1710 hydraulic fluid #1
Nolo263
1986 Ford 1710
Does anyone know if this hydraulic fluid is ok for my 1710?
   / 1710 hydraulic fluid #2
I use the same. Traveler has several formulation. Make sure Ford 134a is on the compatibility list in the back of the bucket.
JC,
JC,
Thank you
   / 1710 hydraulic fluid #4
Hi Nolo263,
Got the manual from my shared google drive? It will give volumes required.
I use this oil, works great. I recommend the two gallon jugs, rather than the 5 gallon pail. Was a bit unwieldy to slowly pour it in the funnel while holding the 5 gallon weight. Get an extra jug or two if you are going to fix that leaky priority valve. This is the same oil for the hydraulics, transmission, AND front axles.
   / 1710 hydraulic fluid #5
I second the two gallon jugs as I have done the same.
Hi Nolo263,
Yes Sir Thank You!!! I hope someday I can help you out.
NEW Long Forks (A59000)
NEW Long Forks...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
1974 John Deere 6030 Tractor (A56435)
1974 John Deere...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2006 Dodge Ram Pickup Pickup Truck, VIN # 3D7KS28C66G203434 (A57453)
2006 Dodge Ram...
