1710 hydraulic fluid
   / 1710 hydraulic fluid #1
Nolo263
1986 Ford 1710
Does anyone know if this hydraulic fluid is ok for my 1710?
   / 1710 hydraulic fluid #2
I use the same. Traveler has several formulation. Make sure Ford 134a is on the compatibility list in the back of the bucket.
JC,
JC,
Thank you
   / 1710 hydraulic fluid #4
Hi Nolo263,
Got the manual from my shared google drive? It will give volumes required.
I use this oil, works great. I recommend the two gallon jugs, rather than the 5 gallon pail. Was a bit unwieldy to slowly pour it in the funnel while holding the 5 gallon weight. Get an extra jug or two if you are going to fix that leaky priority valve. This is the same oil for the hydraulics, transmission, AND front axles.
   / 1710 hydraulic fluid #5
I second the two gallon jugs as I have done the same.
Hi Nolo263,
Yes Sir Thank You!!! I hope someday I can help you out.
E-Z-Go Electric Utility Cart (A55851)
E-Z-Go Electric...
2014 AIIU DH 4-17 HYD SCREENING BUCKET (A57192)
2014 AIIU DH 4-17...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
UNUSED PABREAK BC352 - 72" HYD BRUSH CUTTER (A57193)
UNUSED PABREAK...
2018 Ford F350 (A55973)
2018 Ford F350...
