1710 hydraulic fluid
   / 1710 hydraulic fluid #1
Nolo263
1986 Ford 1710
Does anyone know if this hydraulic fluid is ok for my 1710?
   / 1710 hydraulic fluid #2
I use the same. Traveler has several formulation. Make sure Ford 134a is on the compatibility list in the back of the bucket.
JC,
JC,
Thank you
   / 1710 hydraulic fluid #4
Hi Nolo263,
Got the manual from my shared google drive? It will give volumes required.
I use this oil, works great. I recommend the two gallon jugs, rather than the 5 gallon pail. Was a bit unwieldy to slowly pour it in the funnel while holding the 5 gallon weight. Get an extra jug or two if you are going to fix that leaky priority valve. This is the same oil for the hydraulics, transmission, AND front axles.
   / 1710 hydraulic fluid #5
I second the two gallon jugs as I have done the same.
Hi Nolo263,
Yes Sir Thank You!!! I hope someday I can help you out.
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
UNUSED (2) 5200# DROP AXLES W/ BRAKES (A57192)
UNUSED (2) 5200#...
(3) 6' X 4' EXPANDED METAL (A57192)
(3) 6' X 4'...
Unused 2024 AGT H15 Mini Excavator (A55851)
Unused 2024 AGT...
TURN PLOW (A57192)
TURN PLOW (A57192)
UNUSED 1RANCH 1RETC HYD THUMB CLAMP (A57193)
UNUSED 1RANCH...
