1710 Ford Tractor!!
/ 1710 Ford Tractor!! #1
Fishman1227
Cassville
Ford 1710
I have a 1710 Ford Tractor. I want to know, can I add a remote Hydraulics for the rear of this tractor? It has already a front end loader on it now..
Thanks
/ 1710 Ford Tractor!! #2
If you have hyd on it now, is it easy enough to add to the hyd system.
Tractor Data says you have a total pump flow of 7.8 GPM.
Is this a new type loader valve, with a PB port, and if so, you can add a remote valve.
Ok, I'm not sure about that. What is a PB port??
/ 1710 Ford Tractor!! #4
If you have a loader valve with PB, you will have seven hoses.
You may have the PB port and not using it.
Look on your valve and see if there is a stamped PB by one of the ports.
PB is used to pass fluid to the next valve.
Valves with out PB use the return port to pass fluid to a tank/reservoir.
Ok I will go look!! We just got done with a 13" snow.. so it will be a bit before I post back!!
It has 4 coming from the side and 2 from the bottom with a fill line from the trans. Looks like you could add one more if need be, but I'm not sure.
/ 1710 Ford Tractor!! #7
I have a 1710 ford tractor with 3 lines coming from the transmission to the control valve for the front loader.Can I hook into 2 of these lines for a 3 point hitch backhoe?If so which lines do I hook into?
2008 Honda Civic Coupe (A64557)
2008 Honda Civic...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2015 John Deere 332G Skid Steer w/ Bucket (A63688)
2015 John Deere...
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
