1710 Ford Tractor!!
/ 1710 Ford Tractor!! #1
Fishman1227
Cassville
Ford 1710
I have a 1710 Ford Tractor. I want to know, can I add a remote Hydraulics for the rear of this tractor? It has already a front end loader on it now..
/ 1710 Ford Tractor!! #2
If you have hyd on it now, is it easy enough to add to the hyd system.
Tractor Data says you have a total pump flow of 7.8 GPM.
Is this a new type loader valve, with a PB port, and if so, you can add a remote valve.
Ok, I'm not sure about that. What is a PB port??
/ 1710 Ford Tractor!! #4
If you have a loader valve with PB, you will have seven hoses.
You may have the PB port and not using it.
Look on your valve and see if there is a stamped PB by one of the ports.
PB is used to pass fluid to the next valve.
Valves with out PB use the return port to pass fluid to a tank/reservoir.
Ok I will go look!! We just got done with a 13" snow.. so it will be a bit before I post back!!
It has 4 coming from the side and 2 from the bottom with a fill line from the trans. Looks like you could add one more if need be, but I'm not sure.
/ 1710 Ford Tractor!! #7
I have a 1710 ford tractor with 3 lines coming from the transmission to the control valve for the front loader.Can I hook into 2 of these lines for a 3 point hitch backhoe?If so which lines do I hook into?
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
