1700b Yanmar, question
/ 1700b Yanmar, question #2
As long as the tractor is not running and there is no load on the 3 point hitch there shouldn't be any hydraulic pressure on the valve. I would suggest shutting the machine off, lowering the hitch and cycling the lever several times then you're certain to be good-to-go.
Thanks, I am pretty shure the spring in there may be broken.
Location (A63111)
Location (A63111)
Year: 2015 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 165,169 Plate: Body Type: 4 (A61573)
Year: 2015 Make...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
12ft S/A Utility Trailer (A61574)
12ft S/A Utility...
Precison Planting Air Compressor (A63117)
Precison Planting...
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
