1700 hydraulic screen
/ 1700 hydraulic screen #1
yannie1700
near erie pa
ym1700
Hi,
I figured since i had all the hytrans drained while replacing my rear axle housing it would be a good time to check the hydraulic screen since I have never done so, after pulling the bolts and the assembly out i found that there was very little screen left. Since I have apparently been running this machine for a long time without the benefit of the screen is it an absolute necessity to have it there?? I have temporarily just replaced the cover since the spring and rod that runs through the sping kinda flop around in there also I have removed the o-ring as it was damaged. Am I going to damage my little machine by running it this way???
Thnaks again
John
/ 1700 hydraulic screen #3
" Am I going to damage my little machine by running it this way???"
Probably, I wouldn't want the stuff that clogs those screens up running through my hydraulic system.
Well I just got off the phone with aaron at hoye thanks for the help and good info........anxiouslly awaiting my parts my grass needs mowed and i have holes to dig.
thanks again
john
Ok i just recieved my screen and have a question, what holds the screen in place once its insertd in the tractor??? I have nothing to go by since mine was "rotted" away and only small fragments were left. also what size is the o-ring that accompany's iti was told 16mm but that cant be right.
thanks again
john
/ 1700 hydraulic screen #6
The old type filter screen for the YM1700 is held in place by a 6m threaded rod & nut, there are 2 O-rings 1 G50 and 1 G60. The new type has a spring that goes up inside the screen and it has 1 P50 O-ring. I can Fax or e-mail an exploded view of both types
Danny
i looked at it and have no problems other than getting the o-ring you were out of stock the other day and im trying to match it at napa and having a hard time without knowing the size
/ 1700 hydraulic screen #10
I don't know if napa would have them, my local napa does not. You should be able to find it at most any place that sells bearing & seals. If you can't find one let me know and I'll send one to you.
Danny
2014 Bobcat T870 (A64126)
2014 Bobcat T870...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
4' Mower Blade (A62679)
4' Mower Blade...
