16k trailer with 14500 payload.
   / 16k trailer with 14500 payload. #1
Fixastuff
Massey
I'm shopping 16k trailers and I found a company making one with an advertised 14500 payload. It has dual 7k axles and weighs 3100lbs. How is this possible? Seems like it would have to have 8k axles and only weigh 1500lbs to make this happen. What am I missing?
   / 16k trailer with 14500 payload. #2
Sounds like a nomenclature error to me. Likely the gvwr is 14.5k with axles rated 7250 each. Payload is gvwr as determined by the lowest rated component minus trailer tare weight.
   / 16k trailer with 14500 payload. #4
By the advertising verbiage makes me wonder if 8k axles but derated for something like tires to 14.5k gvwr versus the 16k. I would think that if you're seriously considering it would warrant a phone call before purchase
   / 16k trailer with 14500 payload. #6
Are they adding tongue weight to get the 16k number?
Payload would be defined by what we load on the trailer. No adjustment for tongue weight. Sounds better that way.... :)
   / 16k trailer with 14500 payload. #7
My guess is They are shifting load over to the truck, but they would have to also raise the GVWR.
It’s probably a combination of a misprint and/or a mistake.
I see that out of trailer sellers quite often.
I like the 17.5’s and the oil baths. Although usually 7k’s are not oil bath, but 8ks are. Nice trailer!
   / 16k trailer with 14500 payload. #8
post number 8
   / 16k trailer with 14500 payload. #9
Yeah you hear about it once in a while where the trailer manufacturer is gaming the stats a bit by taking out the tongue weight to "add back" some capacity to allow the axles the meet their rating. Technically the tongue weight is carried by the truck, not the trailer axles. Seems like a bad game to play, IMO, but they do it...
   / 16k trailer with 14500 payload. #10
Some of the load is carried by the tow vehicle. How is "payload" defined?
For my gooseneck, GVWR of the trailer= trailer weight + payload. Since it's a goose neck, 15% of the GVWR should be carried on the tow vehicle. If the trailer has 7000 lb axles, the total load on the trailer axle should be less than or equal to 14,000 lbs. Our trailer weighs about 5000 lbs empty. if the trailer GVWR =16,000 then 16000 x 0.15= 2400 lbs is carried on the tow vehicle and 16,000 -2400=-13,600 lbs the trailer axles. The payload is then 16,000 -5000 = 11,000 lbs. The tow vehicle must be rated to take the total load, called the gross combined weight rating GCWR. If vehicle axles are not rated for this then payload must be off loaded to meet the GCWR
This is my understanding of this issue.
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
LINDE H70 FORKLIFT (A52472)
LINDE H70 FORKLIFT...
2006 INGERSOLL RAND AIR COMPRESSOR (A52472)
2006 INGERSOLL...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
