16hp B&S OHV Compression specs ?
/ 16hp B&S OHV Compression specs ? #1
MattMc
Lancaster, Pa.
JD 300, Allis Chalmers 170XT
Anyone tell me what the compression should be on a 2004 16hp OHV B&S engine. It's from my Toro 16-42Z if that matters.
/ 16hp B&S OHV Compression specs ? #3
Yeah, wasn't sure how the compression release worked on the newer engines but that clears it up, stupid idea. I just want my old world style B&S engine of yesteryear !
I got 60psi out of it dry so evidently it's within the specs. :rolleyes:
Myself nor a friend can figure out what's wrong with it and were both fairly well versed on small engines to a point. Governor's working properly, carb tore apart and cleaned even though nothing was in it. Has good spark, spark plug is dry with little carbon on it. Fuel filter is good, lines are good. Valves adjusted.
Hard/slow to start. Eventually fires up but once running, hitting the gas it bogs and then slowly revs. doesn't seem to reach peak rpm's anymore. Turn on the deck and it bogs and again, slowly comes back to speed. Trying to mow anything thick or heavy and it falls flat on it's face. It act's like a carb issue but it's been torn apart twice and cleaned only to find nothing. I say torn apart as removed from the engine, float bowl and jet removed and passages blown out and carb cleaned. :confused:
/ 16hp B&S OHV Compression specs ? #5
does it have a fuel pump. My kohler command has a diaphragm fuel pump driven off of crank case pressure fluctuations and the diaphragm sort of pulled out of the housing and folded over inside of it. It was weird but I just put it back together correctly and it ran way better.
When you say filter is good, are you sure there is not a strainer in the tank as well?
Small engines are not what they used to be.
25in Wagon Wheel Chair (A65583)
25in Wagon Wheel...
New Holland 463 Rotary Disc Mower (A66408)
New Holland 463...
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
2015 Global M3 Street Sweeper (A64556)
2015 Global M3...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
