16hp B&S OHV Compression specs ?
/ 16hp B&S OHV Compression specs ? #1
MattMc
Lancaster, Pa.
JD 300, Allis Chalmers 170XT
Anyone tell me what the compression should be on a 2004 16hp OHV B&S engine. It's from my Toro 16-42Z if that matters.
/ 16hp B&S OHV Compression specs ? #3
Yeah, wasn't sure how the compression release worked on the newer engines but that clears it up, stupid idea. I just want my old world style B&S engine of yesteryear !
I got 60psi out of it dry so evidently it's within the specs. :rolleyes:
Myself nor a friend can figure out what's wrong with it and were both fairly well versed on small engines to a point. Governor's working properly, carb tore apart and cleaned even though nothing was in it. Has good spark, spark plug is dry with little carbon on it. Fuel filter is good, lines are good. Valves adjusted.
Hard/slow to start. Eventually fires up but once running, hitting the gas it bogs and then slowly revs. doesn't seem to reach peak rpm's anymore. Turn on the deck and it bogs and again, slowly comes back to speed. Trying to mow anything thick or heavy and it falls flat on it's face. It act's like a carb issue but it's been torn apart twice and cleaned only to find nothing. I say torn apart as removed from the engine, float bowl and jet removed and passages blown out and carb cleaned. :confused:
/ 16hp B&S OHV Compression specs ? #5
does it have a fuel pump. My kohler command has a diaphragm fuel pump driven off of crank case pressure fluctuations and the diaphragm sort of pulled out of the housing and folded over inside of it. It was weird but I just put it back together correctly and it ran way better.
When you say filter is good, are you sure there is not a strainer in the tank as well?
Small engines are not what they used to be.
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
1000 GALLON FLAT BOTTOM POLY TANK (A64278)
1000 GALLON FLAT...
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A64553)
2025 GIYI GY-P45...
2026 VR59 59in Vibratory Roller Skid Steer Attachment (A64553)
2026 VR59 59in...
