1635 Box Blade
   / 1635 Box Blade
A 1,600' gravel driveway will take an awful lot of time to maintain with a Box Blade as your primary tool. I second MtnViewRanch that a Land Plane should be your choice if gravel driveway grading is your priority job.
I'm sure you two are 100% correct but I gotta watch my pockets. They don't go so deep. After reading here and what you and MtnViewRanch have said as well as others I'll probably save for a Land Plane for next spring. They do look like an excellent implement.
   / 1635 Box Blade
That is very odd that they have it listed that way. (I'm sure that it is a mistake) How in the world would they know how much power you were putting to the PTO with a 30HP engine? What if you had a gear model, way more power. It has to be mistake. I have seen others as well, not the first and I'm sure it's not the last. :(
Just got off the phone with the the LP dealer. My FDR1672 should be here within 2 weeks he said.
   / 1635 Box Blade #43
Went ahead an got a howse from the dealer for a good price. Now I'm torn between the LP1672 finish mower, Bush Hog RDTH 72 mower, and Howse C372 the dealer want to sell me. Leaning towards the LP but would like to buy from the dealer. He's been pretty good to me. I just don't know much about the Howse mowers. Any ideas on which of the three would be the best?
If you got the one you originally listed from your dealer, then it is fairly light. About 55lbs/ft I think. It will still work fine, but be sure to use it carefully or you'll twist the 3ph attachment area. Just be mindful while you use it and it will work well for you.
   / 1635 Box Blade #45
Land planes are apparently the nuts for driveway maintenance but not for all the digging it sounds like you plan on doing, so the box blade may have been the best first choice.
We made the same choice in getting the boxblade first, now I'm collecting the metal to construct a land plane.
Ditto going with the bigger mower, it does speed the process and no matter what you'll still have areas you need to mow on foot and/or trim with a string trimmer, etc.
Congrats on the new toys, use them in good health!
Thomas
PS: DO consider either weighting your tires ("beet juice"/Rimguard, windshield washer fluid, RV Antifreeze, or Calcium Chloride Solution, OR wheel weights, or both- either will help your traction and lower your center of gravity. Apparently, wheel weights will also reduce your front axle loading.
T
   / 1635 Box Blade
Thomas
T
Gonna try and get a land plane in the spring. The tires were filled with washer fluid. So far so good.
   / 1635 Box Blade
HOO-RAH! Just hooked up my new land pride mower and gonna go try it out tomorrow weather permitting.
   / 1635 Box Blade
Got rained out today Will so I didn't get to try it out. Here's a few pics.
   / 1635 Box Blade
It came on down the road with it.
   / 1635 Box Blade
6.2L 3.73 rears
   / 1635 Box Blade
HA. Ha.
Bout 10.5 or 11 around town. Can get 15 out of it on the interstate if I'm easy with it.
   / 1635 Box Blade
This is the first Ford I've ever owned. Was a Chevrolet guy for 26 yrs up until this one last November. So far it's been a great truck. Traded a 2011 Chevrolet with the 6.2 in it. It pulled well also.
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
296385 (A57192)
296385 (A57192)
2017 Toro Sand Pro 5040 Bunker Rake (A59228)
2017 Toro Sand Pro...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
S/A Utility Trailer (A59231)
S/A Utility...
2017 JOHN DEERE 310SL BACKHOE (A60429)
2017 JOHN DEERE...
