dirthead
New Brunswick canada
I wish
Ok I have a problem.
I have available to me several makes and models of scut's, and no idea which to pick. all are within 10 mins of here.
There's a Kubota/ Massey dealer, a JD dealer, and a mccormick/landini/kioti/cub cadet yanmar dealer.
i've narrowed it down to I think the massey gc2400 14,900 tractor loader, the Mccormick ctj 16,500 tractor loader, or the cub 18,500 tractor loader.
does the last price seem quite high? it does to me.
Any input would be appreciated.
I have a GC2600 and love it I sat a bunch of tractors inculding the Cub and JD but for the price and more important the comfort the Massey worked for me.
what are your intended uses? Brand makes less of a difference as long as you are compairing models in roughly equal economic and manufacturing tiers ).. ( IE.. can't compair $ for $ and HP to HP a chinese jinma to a JD .. etc.. ).
Post some ideas about terain, and intended uses and you will get alot better info from the membership here.
good luck, looking forward to hearing back.
soundguy
Thanks guys, I have 2 acres of which 1.5 are wooded. so mowing is of less importance to me. the driveway is about 160' long and we get lots of snow here. I'd like to do some work in the woods ie hauling trees pulling stumps etc.
Also I want a tiller so we can make and maintain a good sized garden aprox 50'x30' for now. And the ground is very hard here, lots of gravel. I'll be digging up earth mostly for landscaping etc.
I'm leaning a little more towards the Mccomick because it has a greater ground clearance, 10" compared to the others at about 8", and the loader is stronger, hitch is stronger, just looks more rugged, and it comes with the rear hydraulics too.
My opinion, I really have no experience with them.
since you will be tilling.. and sounds like laoder work.. go ahead and get opne with a good trans option.. the more gears the better.. or HST... 4wd and PS.
Pulling stumps? Probably one o fhte best ways to hurt yourself or the tractor or both....
soundguy
Which model Cub?
soundguy
Yup.... also a great way to find out how good your warranty is - and if your dealership has a top-drawer mechanics group!
Rent an excavator or hire someone to deal with the stumps (and the trees). Especially given that the acreage is reasonably small.
Go with the dealership that has the best overall support; part's, repair, etc.
(Ideally, those same folk's just happen to ALSO have the tractor that fits you and your projects the best!)
Good luck.
AKfish
The SCUT size tractors will do what you are aiming for but you might consider looking at a 20 something HP CUT as well. Small CUTs are not much more than SCUTs. They tend to be more capable in ground engaging tasks as they are heavier and have better ground clearance. You might find tilling, tree removal, driveway maintenance and snow clearing a bit better with a heavier tractor. Check out the 20ish hp Mahindra, Kioti and Kubota models. JD790 too. I cannot recall the name of the NH in this category but it would also be worth a look.
Since you state that mowing is of less importance to you, I'd seriously check into small CUTS like the Kubota B-series, JD 2xxx series, and comparable machines. Where SCUTs really shine vs. small CUTS is when a multi-purpose lawn mowing machine is the primary need. For ground engaging tasks and working in the woods, you won't regret having more ground clearance and more weight, nor will you regret having higher hydraulic flow and lift capabilities with a CUT.
Figuring out what to buy is trickier. Figure out what fits your budget and what fits you best. Get in the seat and make sure there's room to operate the tractor comfortably. Buy from a dealer with good support after the sale, but don't decide on a tractor strictly for the dealer (but the dealer can be a tie-breaker between 2 tractors you really like). You may have to drive a bit, but so long as the distance is reasonable, get THE tractor you want from the best dealer around for that brand.
All of the major brands make good machines that are very close in quality.
With regards the JD product, it might be helpful for you to visit their website and then try a few configurations using the "Build Your Own" tool. You should be able to select Canada pricing.
A 3032E with discount might be in the price range you are considering.
The real selling price of a JD is frequently much less than the on-line price their website gives.
Exactly. In my case the stars and planets aligned to produce 25% + off MSRP. In the case of the OP if he even got 10% off on a 3032E that would put it right in the middle of his range of quotes.
There may be other brands that have web pricing, I'm just more familiar with JD and so far it is the only one I've found that provides Canadian pricing.
That's why I was considering the mccormick.
Higher ground clearance same as cut, stronger hydraulics lift capacity at ball end 1433 lbs compared to a massey 1523 cut at 1190 lbs at ball end. it also weighs more at 1609 lbs the massey cut weighs 1532 lbs shipping weight. It has standard mid pto and rear remote valve. at 16500 + tax for tractor loader, with 5 yrs 0% 0 down, it sounds pretty good.
The only things I'm concerned about are the hydrostatic drive pedal (heel-toe) and you don't hear a lot about the new mccormicks yet. hard to find info from owners. here are some pics, as you can see the mccormick is identical to the landini.
Here's a couple more pics. you can see the pedal here.
By the way what tires do you reccomend, I'm thinking industrials
Hi Dirthead,
The type of work you described is similar to mine, I bought a Massey F. GC2310 TLB (Tractor, Loader & Back-hoe++, now replaced by the GC2410) for 18500. I really like the back-hoe for pulling stumps and big rocks, it may look small but it's impressively strong.
Ground clearance can be an issue though. But with patient and caution, you can get pretty far with a SCUT but a CUT with bigger wheels may be better for you if you think you don't need the back-hoe (and keep the price reasonable).
Are you thinking of a snowblower eventually? If yes, consider an HST transmission.
In ruff terrain with rocks and stumps, R4 with rim guard is certainly something to consider also. In my case, I would have probably puncture any other types (lots of blasted sharp rocks).
Good luck!
Thanx Max the gc2400 is actually one that I'm considering. I don't know why I'm killing myself to make this decision, these tractors seem to really keep their trade in value. So if I do end up getting the wrong one, I can always up or downsize accordingly without going broke.
Does that make any sense ?
I've been shopping for over a year and still haven't decided, I think I'm waiting for the next great thing to evolve.Also I usually think outside the box so I'll prolly get something different from everyone around here.
My next door neighbor has a MF 2300 TLMB, across the street has a Kubota BX 2230 I think? His neighbor also a K with MBL, little further down the road has a JD CUT not sure which, looks like a 2520 with LB
By the way the B's stand for blowers not backhoes.
Some tractors have the joystick mounted on the FEL (as in the pics you posted). Others have the stick fender mounted. Be sure to try both types and ask yourself which you prefer and which would be more comfortable over extended use.
Funny thing happened today, I went for a drive and stopped in at the Mccormick/Landini,CC/Yanmar, Kioti dealer to have a look around and chat a little, and was offered a sales job.
I'm really considering it as I'm not very happy at my current job (furniture delivery and building maintenance).
I thought this might be a good opportunity to grow with the company as it is only 2 yrs old. I do have prior sales experience and tractors are an obsession of mine as of late (I'm not getting any younger) :rolleyes:
This could be just what I was searching for for all these years.
Any opinions?
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
211453 (A62131)
211453 (A62131)
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
2006 Volvo VNM T/A Day Cab Truck Tractor (A61573)
2006 Volvo VNM T/A...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
