1610 water pump
/ 1610 water pump #1
Simpleman
I need a water pump for a Iseki 1610 ? No water is circulating in the radiator and it over heating after 20 min. of use.Iam pretty sure its the pump.
/ 1610 water pump #2
Is the bearing out or the housing cracked? bearings worn have it rebuilt, housing cracked call rainbow dist out of Hawaii they should be able to help.
/ 1610 water pump
Thanks for the reply Timmy . Ive already remove the pump and its being rebuilt as I type. I guess I should have preformed a search for
"Water Pump " on this forum before I made my post. Good info in here !! Thanks alot !!
/ 1610 water pump #4
Good I hate seeing people buying new and spending that much money on something that can be rebuilt. That is I would rather spend my money on fishing poles and bait.
Tim
/ 1610 water pump #5
Can you give me a recommendation on where to get a water pump rebuilt. I also have a ts1610 and need a rebuilt on a leaky water pump.....
/ 1610 water pump #6
I can supply new, used , or rebuilt pumps.
/ 1610 water pump #7
If you look around on the internet or for some local shops you can find rebuilders for water pumps that will rebuild any type.
Such as
COMMERCIAL WATER PUMP REBUILDERS
I can remember years ago, when the price for a replacement starter for a ski boat was going to be $200 from a parts store. We found an shop that rebuilt any type of boat or car type starter and saved a great deal of $$.
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
