16' trailer
/ 16' trailer #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
16\' trailer
Guys, I'm looking at 16' utility trailers. I need it for my 2500lbs tractor. I had one dealer tell me that square steel tubing was better that steel angle iron, or stronger. What is your opinion on this and trailers in general. I want brakes. 1 axle or 2 axle brakes? thanks, bw
/ 16' trailer #2
Re: 16\' trailer
The trailer should be rated for " x " amount of pounds regardless of what it is built of.
The more brakes the better.
Are you sure 16 feet is large enough for future expansion?
Egon
/ 16' trailer
Re: 16\' trailer
Egon,
thanks, I think 16'is all my F150 can handle. 16 is big enough for the tractor and one implement. bw
/ 16' trailer #4
Re: 16\' trailer
<font color=blue>square steel tubing was better that steel angle iron, or stronger</font color=blue>
Probably true, but of course it depends on size, thickness, etc. of each, so I'm guessing that he was probably right about the particular angle iron and square tubing he was talking about. And single axle brakes are better than no brakes; two axle brakes better still.
/ 16' trailer #5
Re: 16\' trailer
Probably true, but of course it depends on size, thickness, etc. of each, so I'm guessing that he was probably right about the particular angle iron and square tubing he was talking about. </font color=blue>
pound for pound square or rectangle tubing of the <font color=blue>same dimensions </font color=blue> [/b]IS[/b] is stronger than angle iron. Ie a 2X2 X 1/8" tube is stronger than 2X2 X 1/4" channel. Has to do with the Moment of inertia
/ 16' trailer #6
Re: 16\' trailer
I agree. When I said "size, thickness", perhaps I should have said "different dimensions?"/w3tcompact/icons/grin.gif
/ 16' trailer #7
Re: 16\' trailer
I have a 16 footer and when I went comparison shopping that was the big difference between trailers. Some used 2 inch angle, some 2 inch square tube. BIG difference in strength between the two and the cost isn't that much more so it's what I bought. Labor is about the same, maybe a little more since your welding 4 sides vs 2 and the material itself is a little more but if you're going to have the trailer for any length of time I think it's well worth it.
/ 16' trailer #8
Re: 16\' trailer
If you plan on keeping the trailer forever and keep it outside or in a high humidity area you might think about rust. If it starts rusting badly inside the square tubing you won't be able to see it and it will be almost impossible to sandblast out and paint. You can paint angle iron on both sides from the gitgo and avoid the problem. I've seen some old square tubing built lowboys around here you can stick your finger through in some places.
/ 16' trailer #9
Re: 16\' trailer
Something to consider regarding strength/longevity - Every truck & tractor I've ever seen has a boxed steel frame. Never seen an angle iron frame on a Ford. /w3tcompact/icons/wink.gif
/ 16' trailer #10
Re: 16\' trailer
Not trying to be a smart *ss or wise guy, guys . . . just sharing some general information to clarify a few points and shed more light on the subject.
From a strength standpoint, it is the "section modulus" that determines a particular steel members capacity whether its an angle or square tubing.
From a deflection standpoint (amount member will bend when loaded), the "moment of inertia" will determine this.
Generally speaking, closed members / sections such as a tube or pipe tend to be more "stable" (this does not necessarily always stronger) than "open" sections such as angles when comparing members or roughly similar dimensions. This is not from trial and error guessing, it is from published steel property charts for each individual size and shape section.
Of course, practically speaking, assuming adequate capacity in whatever member you choose, the bottom line choice will probably be determined more by the cost of the member, amount of welding required and serviceability (preventing rusting of the member)
In the end, economics (cost and future serviceability) is what governs most all of our decisions.
/ 16' trailer #11
Re: 16\' trailer
I think your'e right. The required section modulus is based on either the the first moment of inertia [ shear ] or the second moment of inertia [ bending moment ] whichever is greatest. Then the required material is picked on a cost basis. Hope my memory was right on this.
Egon
/ 16' trailer #12
Re: 16\' trailer
I understand your point, which really doesn't seem to contradict the other points made. Perhaps a little more on the technical side, but along the same line of thinking - e.g. all things being equal, a tube is stronger than an angle.
/ 16' trailer #13
Re: 16\' trailer
Brett,
I agree with all of the statements that for a given size the tube frame is more resistant to the bending moment. I also agree with Egon's assessment that a trailer should be engineered according to a desired LOAD RATING ( 'x' pounds ).
With the required LOAD RATING in mind, the appropriate dimension and thickness of a given material would be selected to meet or exceed the given load rating. The basis for this selection may include many factors, such as construction method, intended use, and cost.
I've seen VERY well constructed trailers with channel frames, and poorly constructed ones with tube frames. The quality of a trailer is as dependent on the design and constuction as it is on the materials from which it is constructed.
You need to evaluate your intended use, cost, and the load rating for the trailer in combination to determine which is better for you.
Larry
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61307)
PENDING SELLER...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2019 FREIGHTLINER M2 26FT CDL BOX TRUCK (A59906)
2019 FREIGHTLINER...
2002 Ford E-250 Cargo Van (A59230)
2002 Ford E-250...
2019 International DuraStar 4300 26FT Reefer Box Truck (A59230)
2019 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
