16 or 18' Trailer
/ 16 or 18' Trailer #11
Re: 16 or 18\' Trailer
I haul my 2910 with loader and box blade on a 20' car hauler with twin 3500 lb axles, one with brakes. 2' of the 20 is a dovetail, leaving me with 18' of useable deck. That's just about right. I sure wouldn't go any smaller than an 18' car hauler.
I kind of wish I'd gotten a 10,000 lb capacity unit, but it was almost 50% more cost and I've got plenty of capacity for my tractor. I don't know how much more a backhoe would add. I always make sure my trailer tires are aired up to the max recommended pressure as well.
/ 16 or 18' Trailer #12
Oh, one other thing I forgot. The dovetail does make ground clearance a problem if you have to cross ditches or the like, as it hangs down in the back. This is less of a problem with a regular utility trailer. If you are always on somewhat level ground, it's not an issue.
/ 16 or 18' Trailer #13
<font color="blue"> My next trailer will be...with slide out or folding ramps. Its a pain to carry a 100# ramp around. </font>
I say this every time someone mentions getting a new trailer so I'd hate to let this time pass without comment. Get a tilt bed trailer and you don't have to worry about ramps at all. /forums/images/graemlins/grin.gif Another advantage is that I don't have a dovetail at the rear taking up a couple feet of flat floor space. My floor length is all useable, loadable space.
I have a 26' trailer with a 22' diamond plate floor. Yes, the diamond plate can become very slippery when it's not dry, but so can wood in many instances, too. The trailer has a hydraulic pump run by an electric motor to power it. This setup has made life so much easier.
I added an 8000# electric winch to mine so I can even load a dead vehicle with no problems at all. With a 40' winch control lead I can even steer something on while the winch is pulling it. Once I get it loaded I level the bed, hook a couple chains on the back then use the winch to take out the slack. A manually snugged safety chain on the front as a backup for the winch brake and I'm good to go. /forums/images/graemlins/grin.gif
That method works so well that now I tend to use it even with a running vehicle. It doesn't add much if any time to the process and I have much more control than I would driving it on. it's especially helpful if I'm loading something with which I'm not going to have much margin for error on centering it because of it's width.
/ 16 or 18' Trailer #14
I bought a Big Tex Trailer Model 10 PI.Which is a 10,000 pound trailer with brakes on both axles and a breakaway kit.
Here is the link to their page.Good Luck in Your search!
Big Tex Trailers
/ 16 or 18' Trailer #15
i just did this last year...went to an 18 ft trailer, but no dove tail...allowed me to haul 6 round bales of hay at a time instead of 4 on a 16 ft trailer...plus everything fits better...18 ft trailer, with 5 new tires, wood bed, 3500 lb axles..@ $1300, last year..
heehaw
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Coats 5040A Tire Changer Machine (A59230)
Coats 5040A Tire...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
Abaco Machines DVL500 Vacuum Lifter (A59230)
Abaco Machines...
2016 Volkswagen Tiguan SUV (A59231)
2016 Volkswagen...
