16 MPA = how many GPM ?
/ 16 MPA = how many GPM ? #1
acadian32
Ottawa
Jinma 254
16 MPA = how many GPM ? thank you
/ 16 MPA = how many GPM ? #2
MPA is pressure.
16 MPA = 2320 psi.
Thank you JJ any idea about what GPM that is = to? reason im asking the local store here only has the specification to pumps by GPM
/ 16 MPA = how many GPM ? #4
Pressure only comes when the flow is restricted.
Max flow comes when there is no restriction.
GPM is strictly a function of displacement X frequency (RPM)
The specifications are at odds.
Think of it, What is the "pressure" of the water as it flows out of your kitchen tap?
You might have an idea that the pressure drops when flow is unrestriced if you have ever taken a shower and had the toilet flushed ;-) The flow restriction in this example is the shower head, and water pipes.
In the same way, a tiny pump can develope large pressure values if the flow is very small. Dead end a positive displacement pump, and something breaks! That is why there are pressure relief valves built into most every pump.
Pressure and volume are difficult to relate. But when you do, WORK , i.e force through a distance, will become understandable, and with the added element of time, "Horsepower" becomes calculable.
/ 16 MPA = how many GPM ? #5
gpm is a flow rate, and not a pressure (like MPa), so you can't equate the two. They are two different things.
You can relate flow rate (gpm) to pressure (psi or MPa) by knowing the operating characteristics of the system, but that has to be measured or tested. As an example, pumps will have operating curves that show gpm as a function of pressure and/or head loss.
/ 16 MPA = how many GPM ? #6
A pump will use a certain amount of HP, so one has to select a pump with the characteristics he desires.
Mas rpm, pressure rating, speed of pump, cu in displacement, shaft size, port size and type. .
Cu in and and speed of pump will determine the GPM.
/ 16 MPA = how many GPM ? #7
The local store is right, the pumps should be spec'd in GPM. If you are looking for anything that is 16MPa I'd say you are looking for the relief valve on the pump.
Where, may I ask, did you get this 16MPa specification from that you are trying to match? Perhaps knowing more about your situation will give us a better understanding of how we can help.
/ 16 MPA = how many GPM ? #8
Some pumps don't list GPM, rather displacement. Usually in cubic inches per revolution. Flow is going to be determined by the displacement and how many rooms the pump turn.
Thank you all very much for the help... current pump I have is a CBN-E17 pump spec.jpg see label picture attached, I ordered a new pump but it would be nice to find close match from this local site Search results for 'hydraulic gera pump' | Princess Auto because I have family that own a machine shop in New Brunswick that would be able to make a matching flange and shaft.
/ 16 MPA = how many GPM ? #10
Thank you all very much for the help... current pump I have is a CBN-E17View attachment 424230 see label picture attached, I ordered a new pump but it would be nice to find close match from this local site Search results for 'hydraulic gera pump' | Princess Auto because I have family that own a machine shop in New Brunswick that would be able to make a matching flange and shaft.
Good morning Acadian, the pump flow is 14ml/rev (14ml = .0036984 US gallon or .003079 IMP gallon)) and is rated for 2000 RPM so your pump is 7.39 usg or 6.15 IMP gallon at a max of 2000 RPM at a max PSI of 2320.. what shop is that in NB... Jim
/ 16 MPA = how many GPM ? #11
You are right, and my post was wrong, so I deleted it.
Thank you guys... the shop in NB is McKiel Mechanical Ltd you guys could not imagine the talent my uncle has... he an big mud bog and the only good machine on the road are Jeep's this guy is unbelievable he will make his on treads on his tires make custom rads but he is finally retiring on Dec and his son just as talented purchase the company and have a feeling he will bring the shop to a hole new level of services. the prime services was drive shaft and custom parts for the mine that closed down a few years ago. I have to talk to my cousin to take a good look at this site and could see great opportunity and helping folks on these site " win win for all "
/ 16 MPA = how many GPM ? #13
Yup i know where his shop is in Bathurst, i'm in Fredericton and travel up that way lots.. Jim
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
Caterpillar TL1055D (A62177)
Caterpillar...
Generator (A61572)
Generator (A61572)
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
