16.5 briggs
   / 16.5 briggs #1
truckdriver23us
minnesota
craftsman 52700
runs smooth if choke is not open all the way . but surges when choke is open .adj. carb dont seem to do anything. any ideas? thx e1 .
   / 16.5 briggs #2
Check base of carb for looseness or bad gasket which will cause a vacuum leak. Also, condition of fuel (water in tank, dirty filters)
   / 16.5 briggs #4
Sounds like there is probably some crap in the main jet of the carb -- take it off - get a gasket set and clean it out. Usually when a Briggs runs ok with the choke on but not with it off the carb is the problem -- JMHO
   / 16.5 briggs #5
Stop by NAPA and get a can of carb cleaner.Dissassemble the carb completely removing all plastic and rubber parts.Pick up a carb rebuild kit from your local small engine shop.These parts are specific to your engines Model#Type# and code #s be sure you have all the #s.I use acetelene torch tip cleaners to carefully clean out all the crud that tends to build up in passages and jets in the carb.You can also use the wire in a bread sack tie.Blow out thouroughly with compressed air.Install a new in-line fuel filter,this should remedy your problems.Best of Luck:thumbsup:
Scotty
5420 John Deere Tractor (A52384)
5420 John Deere...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51691)
2016 Ford F-450...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
Kubota M6800 (A50123)
