1575 Loader on a 336D
/ 1575 Loader on a 336D #1
Batguano54
Hello,
I recently purchased a 336D with a 1575 loader on it. I would like to remove the loader in order to do some maintenance on the engine. The loader has quick-disconnects on it. Will I have to by-pass the loader valve (in to out) to keep from destroying my pump?
Thanks for any info,
John
/ 1575 Loader on a 336D #2
Yes, you do need to insure the fluid from the pump continues to flow with the loader disconnected. I made up a short hose to plug into the quick disconnects to replace the loader connections when it is removed. Failure to keep the fluid flowing will insure failure of some component, most likely the pump.
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
2005 Sterling Cab (A66736)
2005 Sterling Cab...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2022 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
2022 Ideal BB4LD...
2014 FORD F-150 (A67714)
2014 FORD F-150...
2017 Ford F-450 XL (A64911)
2017 Ford F-450 XL...
