155d hydraulic Question
/ 155d hydraulic Question #1
gary1611
I have a Front plow Which i currently use a winch to lift because the dealer could not find the hydraulics. I want to make it lift with hydraulics. <font color="red"> Is there a Port that i can hook a hose into to control it with the three point control. </font> Or maybe somebody here has the parts to do it right i'd like down pressure but don't want to do to much fabricating right know. When i build a loader i'll control it with that valve but for know i just want to control it with three point.
/ 155d hydraulic Question #2
Gary,
I think you will need a single controller regardless. You will have to tap into the pressure line on the bottom of your pump (small diameter line), run it to a single controller. like a log splitter controller for example, and to your implement and back to the high pressure side of the tractors hydraulics. I know of no other way to do it.
/ 155d hydraulic Question #3
You can use the 3 point control valve , but it will not have down pressure because the 3 point control valve is a single acting valve. You'll have to do like Mark said for a dual acting cylinder.
I understand that there is no down pressure with three point. was just asking if someone might have origanal plow hydraulic parts.
Can i just hook the into the port under the seat and to the rear of the tractor for up pressure. thankyou
For those that may use this post in the future for reference. My answer is yes.
its a port under and to the front of the seat. Its inline with the 3pt stop valve. There is a port on either side i will try to update when i get it completed. Thankyou to those that replied even the ones who pmed me.
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2016 KENWORTH  W900 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
