1526 added multiple rear remotes, 3rd function
/ 1526 added multiple rear remotes, 3rd function #1
DonE0929
N GA mountains
Mahindra 1526 tlb, Satoh Beaver S370D
I finished this a while back and realized I didn't share my project with anyone. So if anyone is interested I'll do a quick run down.
I have a 1526 TLB and wanted rear remotes for TNT and I wanted 3rd function for a grapple, but I wanted to do it as cheap as I could. The kits available for the third function alone were close to a grand and that's all you got from it was 3rd function... I wanted it all and for as little as possible.
I purchased a 4 bank electrical valve set from summit hydraulics. I also got a 3 set electrical switch box and one loader controler set up with electrical buttons ( for open/close grapple). This was a universal kit so I had to make all my brackets and shorten or extend electrical wires. The electrical switches take up almost no space compared with a manual valve set that I really didn't have room for.
I used my backhoe hydraulics to feed the 4 valve bank ( I obviously only need those when the hoe is on and don't need other functions when the hoe is in use ) I have one valve set running top link, one for side link, one to run 3rd function and a spare set not currently used. The only down fall with my set up is I don't have a set that is continuous flow, but I don't have an implement that needs it at this time. I guess I can't use the grapple with the backhoe, but I usually need the bucket at that time, so no real loss there. The only failure I have had with the system is that the 3 switch panel does not function if it sets over night in below 15 degree Temps. I have to wrap a warm towel over them for a few minutes to get them working.
I have around $1500 in this set up including hoses, fittings and hose protector sleeve not included in the kit. ( I had the top link already). I have a bunch of fittings and adapters that I didn't use, but they were purchased, so counted in the total. The tractor has 3/8 hoses and fittings, the summit kit is all 1/2, so there are a fair number of adapters to come up with. I think I did 2 or 3 orders from surplus center and another from summit to get it all sorted out. I do have one long set of hoses to the front (tucked away under the tractor), but I sectioned them so I don't need to replace a 12 foot hose if I blow one on the third function. There are no hoses in the kit so I had to pick up a few standard lengths from tractor supply and had Napa make a few as well.
I didn't have everything I needed when I got started so it took my about 2 weeks to get all this done, but because i did not cut into any hydraulic lines the tractor stayed fully functional. I didn't get the right electrical cables from summit the first time , or even the second time, but customer service there is great and I got new cables in 2 days both times and free. If I had everything ready I could have don't it in a single day including fabricating the mounting brackets. I had never done hydraulic work before, other than replacing blown hoses.
I have been using the set up for six months or so and can say that the hydraulic top link alone was worth the cost, but the grapple is a great tool as well( althought not cheap). I didn't take build pics, but will answer questions if you have any.
/ 1526 added multiple rear remotes, 3rd function #2
I need to do this. I already have the WR Long third function. Well worth the money in my opinion. I personally wouldn't pay anyone to install this stuff.
/ 1526 added multiple rear remotes, 3rd function #3
We need pictures. Even if they are of your shop cat. Our depth of understanding is much better with pictures. Well,,, mine anyway. :)
/ 1526 added multiple rear remotes, 3rd function #4
my dealer told me that for continuous flow they just add an electrical bypass switch in parallel with the rocker switch (if the valve body will stand continuous flow) this effectively functions as a detent in an electric over hydraulic valve.
2018 Genie GTH-5519 (A64126)
2018 Genie...
(48) Closing Wheels off Great Plains Planter (A65640)
(48) Closing...
300 gal Fuel Tank (A66408)
300 gal Fuel Tank...
1988 Fruehauf 42' Tanker Trailer (A64127)
1988 Fruehauf 42'...
2020 Mahindra 6075 (A64126)
2020 Mahindra 6075...
Misc MJ Fittings (A64127)
Misc MJ Fittings...
