Oil & Fuel 1510 Fuel tank
/ 1510 Fuel tank #1
xspired
Georgia
YM1510D
My 1510 started losing power and stalling 2 summers ago while bush hogging on rather hilly ground. Could not figure out the problem as after cooling for a while would run fine,then noticed while problem was occuring saw that fuel drier/filter was empty. It seem I have trash in fuel tank that sometimes will get caught in fuel outlet.So my question is can someone suggest how to get this trash out short of removing the tank?
/ 1510 Fuel tank #2
You could try sucking the junk out of the fuel tank using a suction gun, the type that looks like a grease gun. But I think you will end up pulling the cowl and taking out the tank.
/ 1510 Fuel tank #3
Get as much fuel out as possible and use a shopvac with some improvised fittings to get a ridgid 1/2 piece of pvc into the hole for suction or a garden hose (im thinking it will suck this shut though). My first thought?
/ 1510 Fuel tank #4
I agree with clemsonfor...another thought would be to again...empty all the fuel and with the vacuum going, blow compressed air through the fuel hose dislodging all of the crap and the wet dry should suck it up as it comes free.
/ 1510 Fuel tank #5
Be careful there are no gas fumes sucked into your shop vac. Those things emit sparks.
/ 1510 Fuel tank #6
Be sure to replace the fuel line that goes from the tank to the filter, or blow it out real good.
/ 1510 Fuel tank #7
You can also wire on a cloth to a dowel (like a big Q-tip) and swab around the bottom of the tank to get what is sticking to the bottom.
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2022 EZ-GO ELITE...
2013 JCB 506-36 TELESCOPIC FORLKLIFT (A65053)
2013 JCB 506-36...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
MUD MIXING FRAC TANK (A65643)
MUD MIXING FRAC...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
