1508 needs gearbox rebuild
/ 1508 needs gearbox rebuild #1
PegAir
Bottom seal blew out on one wing of my 1508 while mowing. Gearbox is toast. Gears were already chipped and worn on this side anyway. Other gearboxes are in great shape.
Took off a bolt that seems to hold the stump jumper assembly to the vertical shaft that comes down from the gearbox, but can't budge the jumper off the gearbox.
Going to try to use some farm jacks to push it off, as the parts book makes it look like it is attached to a spline shaft, and should just slip off.
If anyone's done this before and knows how I should really do it, lemme know in case my project today fails. If it works I'll post back and let ya know how it went.
Probably don't have to take the jumper off to fix it, but I'ld like to work in it in the workshop instead of the weather, and maybe just take it to a dealer to rebuild.
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
2007 JOHN DEERE 120C EXAVATOR (A65056)
2007 JOHN DEERE...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
Set of 3 Trailer Tires (A66734)
Set of 3 Trailer...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
Miscellaneous Generac Generator Accessories (A66734)
Miscellaneous...
