Oil & Fuel 1500D fuel line?
/ 1500D fuel line? #1
Therios Pendragon
Rainier Oregon
Yanmar 1500D
Ok... dumb question...
There is a little black line that comes out of the neck of the fuel tank. It bubbles around it while in operation.
It appears like this little hose goes to the top of the cylinders and what I assume is (are) the injectors.
Does that mean that This is a simple suction fuel system and that there is no fuel pump? Or is this some kind of breather? I can take pictures if there is any issues with identification but I pretty much think the answer will be easy.
/ 1500D fuel line? #2
Should be the fuel return line from the injectors.
/ 1500D fuel line? #3
I think what you are describing are the fuel injector return lines. Excess fuel that the pump sends to the injectors are returned to the fuel tank. It does have a fuel pump. Some call it the injector pump. A diesel will not run without one.
/ 1500D fuel line? #4
IF YOUR SEEING AIR BUBBLES AROUND IT ,CHECK YOUR FUEL CAP VENT HOLE .THE TANK VENTS THRU THE CAP.
/ 1500D fuel line? #5
could it be part of the thermostart?
/ 1500D fuel line?
Wow... what a simple idea... a return... Thanks. I whould have been able to figure that out for myself. But glad the answer came that quickly.
I don't think that my fuel cap has any breather hole. It seems perfectly solid. Maybe that is why the little bubbles around the hose.
Thanks again folks for such a quick response.
/ 1500D fuel line? #7
Can You post a pic of it ? also what it attaches to . My little 1300 just has a little tip that sticks out of the tank neck , no hose & fuel runs out when sloshing around if its more then 1/4 full .
I,ve been trying to figure out what its for & what should be connected to it as it looks like its broke off . Thanks Bob
/ 1500D fuel line? #8
I just took a closer look at Mine. & it does have the line from the injector pump running into the top of the tank. The one I,m talking about is 1/4 inch Hole coming out of the side that looks like it is a vent.
Can anyone confirm if its supposed to have a hose hooked up either on the outside or inside of the tank to Keep it from Slooshing out. Thanks, :confused: . Bob
/ 1500D fuel line? #9
It sounds like you do not have the filter that fits in the inlet to the tank. It has a couple of slots in the lip, allowing the tank to breathe when the cap is screwed down.
/ 1500D fuel line? #10
/ 1500D fuel line? #11
The return line hooks to #4
Danny
/ 1500D fuel line? #12
Danny
Thanks for the pic Danny . I took a couple of pics. Hopefully it will show what i,m talking about. Its right at the bottom of the fuel neck. Theres no hose running into the tank . I,m assuming the return line is the one next it . Or am I wrong ? :eek:
This just apears to be a vent , but the fuel comes out when sloshing around , thanks Bob .
/ 1500D fuel line? #13
It appears that a previous owner added the brass fittings where your return line is connected. On mine the return line goes to the hole at the bottom of the fuel neck. I would just plug that hole since your return line has been moved. I assume your filter is like mine and has the slots to allow venting when the cap is screwed down.
/ 1500D fuel line? #14
Thanks reb :D . I,ll look & see about the slots , But I beleive it does . I,ll give that a try. Thanks again, Bob
CAT 416B 24" Bucket (A68134)
CAT 416B 24"...
FIXED FIFTH WHEEL ATTACHMENT (A67714)
FIXED FIFTH WHEEL...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
2022 BOBCAT T870 SKID STEER (A65056)
2022 BOBCAT T870...
2000 Toyota 4Runner SUV (A66738)
2000 Toyota...
