149 front axle
/ 149 front axle #1
RFR
Sterling,Va.
when I purchased my 149 i knew there was a problem with the front axle. The axle has been installed backward, axle pin is backward, pin will not stay in place. When reversed what holds pin in place. And what size are the pin holes thru channel.
/ 149 front axle
Bob, your parts diagram is different than mine. My problem is the diagram shows all of the parts and pieces but not how they are put togather as a unit. My daigram clearly shows the pin, it only has a spring pin thru one end but not where it is located once the axle is placed in the channel or axle bracket.
/ 149 front axle
Bob, this is the same detail of front axle that I have. Look at the right end of axle pin you will see a small dot, that is a 3/16 hole for a 1 1/4 long spring pin. Trying to find out where it is located once every thing is reinstalled. I have ordered a master shop service manual from Binder Books, hopefully this will tell how all of this is put togather. Thanks for all your info.
Danuser 3 Point Post Auger (A65640)
Danuser 3 Point...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
Air Compressor (A64127)
Air Compressor...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
