1440v loader hyd.
   / 1440v loader hyd. #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
I have a 1440v m. f. with a 1466 loader .. the loader hydrolics seem to be week to me but the dealer checked the pressure and said its fine...is their a way to turn the pressure up ? or any other ideas.? thanks for the help...this is a great site ! thanks Bruce <font color="yellow"> </font> <font color="yellow"> </font>
   / 1440v loader hyd. #2
I've got a 1040 loader and the dealer put a "shim" in my controller that increased the pressure some and improved performance. It wasn't much trouble and took about five minutes.
   / 1440v loader hyd. #3
Yes, your dealer could turn the pressure up, but I don't think that they will (that is above spec.). I don't know how much experience you have, but the way you use a loader has a lot to do with how it works. I have a MF 1440 with the same loader. It has real good power. Another thing to think about, is that your dealer said that it was "fine". From my experience, that might mean that it isn't really far off, but might not be where it really should be. I would get a gage and hook it up to see for myself what the pressure is set at.
   / 1440v loader hyd. #4
Jerry,
I was a little disatisfied with the bucket curl power on mine shortly after I got it and they checked the pressure. It was probably in the acceptable range, but not max for specs. After they worked on it it was at the specified maximum, but I don't remember now just what it was. Just a little bit more pressure but it made a noticeable difference in performance.
   / 1440v loader hyd. #5
Bruce- I'm just curious, what's it doing (or not doing) for you to consider it weak?
   / 1440v loader hyd. #6
That is exactly what I was trying to get at. It might be in range and the dealer might not want to change it, but it would give better performance on the high side.
   / 1440v loader hyd.
Thanks for all the help . The trouble i am having some times it will pick up a bucket full of what ever i happen to be working with at the time and then it wont pick up but half the amount.. Maybe its just me ... I have been working around tractors all my life this is the first time this has happend.... Its the 3 rd. massey ferguson i have owned, but its the first massey loader... the other two were bushhog brand loaders.. Is this shim something i can do myself? Thank you for all your time B.Neal /forums/images/graemlins/confused.gif [image]confused[/image]
   / 1440v loader hyd. #8
It's a adjustment screw under your right floor board. It is behind a hydraulic manifold. It's not easy to get at. I would check the pressure myself first.
   / 1440v loader hyd.
Thanks Jerry,,,, Do you have any idea how to check the pressure ??? Thanks Bruce
   / 1440v loader hyd. #10
If you have remotes you can plug a gage into them. If you don't, there is a 1/8" pipe plug on the pressure pipe where it comes off of the pump. A hose with gage can be made up to work there.
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51244)
KNOW BEFORE YOU...
