1440v loader hyd.
   / 1440v loader hyd.
Yes..thats where i got them......i will try again just to be sure..... thanks
   / 1440v loader hyd.
I did it again with the same results...any ideas ?? could it be set that low ?? i wont have time to check anything el /forums/images/graemlins/confused.gifse until tues.. got to get to work ...while its not raining...thanks for all the help /forums/images/graemlins/confused.gif
   / 1440v loader hyd. #23
You need to do the check at (I think, old age) 2600 rpm. What rpm did you use for those numbers?
   / 1440v loader hyd.
it was at 2600 rpm...i may be doing somthing wrong ?
   / 1440v loader hyd. #25
When you have the rpm at 2600, hold the loader valve to the lock. Then it will build pressure. If you don't do this all you are doing is testing the flow resistance in the system. Sorry that I forgot to mention that.
   / 1440v loader hyd.
ok ...but what do you mean about the lock.....???? i promise i am not as stupid as i seem..... /forums/images/graemlins/grin.gif and i thought i knew alot about tractors.... my dad used to say : Thats what i get for thinking : thanks
   / 1440v loader hyd. #27
What I mean by the lock is to push the joy stick alway to the right or left and hold it there.
   / 1440v loader hyd.
ok ..i will try that tomarrow....should i just hold it until the gage stops moving ?? sorry for all the questions.....
   / 1440v loader hyd. #29
No problem with the questions, just hope that I can help.
Yes, just hold the stick and you will see the gauge move up. Post with your results.
   / 1440v loader hyd.
well i finally got it checked ...the gage peged at 2100psi...i was afraid to hold the valve locked to long for fear of busting a hose..do you think that is accecpable pressure ??? thanks Bruce
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
2015 Kia Sorento AWD SUV (A50324)
2015 Kia Sorento...
International 133 6 Row Cultivator (A50514)
International 133...
2021 KUBOTA U55-5 EXCAVATOR (A51242)
2021 KUBOTA U55-5...
(4) 12-16.5 NHS TIRES & RIMS (A51243)
(4) 12-16.5 NHS...
