1430 hard to start
   / 1430 hard to start #1
menchhofer
Hello
Have 1430 about 850 hours. When turning key to start, at times I hear what sounds like a flap opening or closing and starter does not turn. Turning key off and on several times...getting to be more times until starter kicks in and starts engine. My first thought is starter or solenoid or both but not sure. Pretty sure it is not ignition switch on dash panel or the switch on treadle. Need ideas from people with similar experience. What say you guys? Would appreciate any suggestions and thanks
   / 1430 hard to start #2
If the solenoid just clicks, but doesn't turn over the starter, that is generally indicative of insufficient voltage.
I had a car that would do that... but only when the engine was really warm in the summer after I had driven some place far from home. Deucedly inconvenient, since it is tough to troubleshoot it in a parking lot somewhere 120 miles from your tools. Always worked great in my driveway. The problem was the wire from the ignition switch to the starter solenoid where it ran by the exhaust manifold was corroded. When hot, resistance would go up, voltage to the solenoid would go down.
Solenoid itself could be going bad; insulation in the resistance on the windings breaking down, so that it doesn't have enough magnetic field to overcome the spring.
When the solenoid failed to spin the starter, I would start by running a wire directly from the battery positive terminal and tap it against the solenoid terminal and see if it works. If so, you problem is either the ignition switch or the interconnecting wiring.
If it doesn't, then replace the solenoid.
   / 1430 hard to start #3
I had similar, "solenoid just clicks", turned out my battery was the problem. I checked the wires and connections from the battery to the solenoid, including ground side as well. Typically this type of problem is lose connection, bad cable, battery then solenoid.
   / 1430 hard to start #4
There is an older thread on this. Check the connections. I've had two crimps fail on the metal side of the crimp.
All the best, Peter
   / 1430 hard to start #5
I bet it's the solenoid. My 1430 uses a cheap auto (ford? $10-$15) one.
   / 1430 hard to start #6
Grounding/Connections both sides, Battery, Solenoid, Starter in that order. Then you look at wiring and key.
   / 1430 hard to start #7
Yes, it is a Ford solenoid. I had one fail at the bracket, which is also the ground, leading to...intermittent starting.
   / 1430 hard to start #8
Not sure if it's the heat here in Texas or the vibration. But I replaced mine twice. Intermittent starting both times.
so...replaced starter and installed new battery. Starter solenoid still clicks but not as often as before...completely stumped now.
   / 1430 hard to start #10
I had to look pretty carefully at the crimp on the wire from the starter switch and from the Ford solenoid to the Deutz solenoid to see failing crimps. Both mechanically fatigued and wore through from the vibration.
Two other things occur to me; 1) the battery ground cable and the connection at the engine end, (check to make sure it is clean on all sides and that the cable crimp is good and 2) the key switch. I'm assuming that you recheck the battery cables at the battery and the wire from the Ford solenoid to the Deutz solenoid.
If you can run a hot wire to the Ford solenoid starter and it always starts, it is your key switch. (Leave the key switch in run, and carefully, repeat carefully, take power from the adjacent hot lug.) If not, I'd be looking at the cables. I up sized my battery cables when I bought mine on general principles, and added some extra ground leads to the two tub halves and centrally grounded everything on the engine block.
All the best,
Peter
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
1459 (A57192)
1459 (A57192)
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
