1320 won't start
/ 1320 won't start #1
Rocko
Connecticut
MF GC1710
1320 won\'t start
Turn the key and nothing, no lights no sound, nothing.
The battery is fully charged. I thought it was the ignition switch, installed a new switch but still nothing when you turn the key.
Theres a 20 amp fuse near the battery and that was ok.
what should I try next?
/ 1320 won't start #2
Re: 1320 won\'t start
Rocko, Clean ALL connections from the battery posts to ground on the engine, starter, coil....and so on. Check all fuses with a test light. They may look fine, but it does not mean it is good. And dont for get the seat switch (if it has one.) Let me know if this works.
Good Luck,
Bob
/forums/images/graemlins/crazy.gif
/ 1320 won't start #3
I agree with Bob... probably just a connection problem. Check/clean all the ground and hot cables. If that doesn't do it take a test light or multimeter and see if you are getting a signal from the ignition switch when you turn it to the crank postion.
/ 1320 won't start
I been too busy or when I've had some spare time it's been too cold to work on it.
Thanks for the advice, I will post the resluts when I get time to work on the 1320 again.
CAT 973 GP Bucket (A68134)
CAT 973 GP Bucket...
2020 FORD F-150 XL CREW CAB TRUCK (A65054)
2020 FORD F-150 XL...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2023 Dodge Challenger Coupe (A66738)
2023 Dodge...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2021 Kubota BX2680 25HP 4WD Utility Loader Tractor w/ Attachments and 2021 T/A Flatbed Trailer (A66734)
2021 Kubota BX2680...
