1320 won't start
/ 1320 won't start #1
capitalistpig
I have a model 1320 Cub Cadet with a 12.5 hp Kohler that will not start after 18 years of trouble-free service. Turning the ignition key produces nothing, not even a click. The battery is strong. An inspection of the wiring shows good insulation and terminal connections. Dead-man switches appear to be functioning. Help? Thank you.
/ 1320 won't start #2
Troublehooting with a 12 volt test light is there voltage at the starter solenoid when you turn the key to start? If there's voltage there then ether the solenoid is bad or not grounded. If the voltage isn't there and you are getting voltage to the keyswitch then ether the key switch or one of the interlocks aren't making a connection. Check the back of the keyswitch to find the start terminal and start tracing from there.
/ 1320 won't start #3
I had the same problem with mine. Under the seat and to the right of the Battery, I found a 20 amp Fuse that was blown....it would blow intermittently and the tractor wouldn't start. After doing some tracing of wires, I found wires rubbed thru against the arm that engages the Deck causing the fuse to blow. This might be the diagram for your tractor...depending on Serial #
http://ihregistry.com/wiring/B28.pdf
/ 1320 won't start #4
I have a 1330 and had this problem!! the casing on the wires to my ingnition worn off and one of the wires rubbed another and it blew the fuse!! I had to rewire and get a new ingnition and a new fuse... runs just fine now
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
John Deere 490E Excavator (A62679)
John Deere 490E...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
