Grading 1301D box blade capability
/ 1301D box blade capability #1
CEBO55
Northeast Ohio
Yanmar 1301D
Hi Everyone. Been reading this website at lunch everyday for about a year. Decided to finally join. I have a Yanmar 1301D. I am strongly considering purchasing a 42" box blade to keep the hump and weeds out of my 350 ft long gravel driveway....I hate using poisons. I have 200 lbs of suitcase weights on the front. The driveway is packed pretty hard. Do you guys think this attachment is going to do the job well. This is probably the only task I will use it for....Thanks
/ 1301D box blade capability #2
Welcome CEB055,
Your tractor is not shy of the power necessary to use a 42"-48" box blade...It's usually about front end weight AND traction. If you can keep the front end down and the tires from spinning, you shouldn't have any difficulty ripping up and manicuring 350' of gravel. Small tractors just take a little longer and smaller bites :).
Mark
Thanks for the reply Mark777. Thats what I was hoping to hear. I have used quite a few implements before, but never a box blade. I may actually be able to utilize it for putting in some food plots on my hunting property, I have a lot of thumb size saplings that I need to get the roots out, before I can plant.
/ 1301D box blade capability #4
CEBO55,
Measure the outside width of your rear tires tracks. Let that guide you. That tractor should easily be able to pull a box blade that can cover your tire tracks.
Knute
/ 1301D box blade capability #5
I have a 4 ft box behind my 1602D and I keep about the same length of driveway smoothed off with it just fine, I do have 4 wd tho, and an FEL for front weight. But like the others have said, just take smaller bites, more seat time!
Thanks Knute and Jagmandave for the info. Mine is also a four wheel drive. As Mark777 told me I will probably be restricted by weight in the front end. I have the 200 lbs of suitcase weights, but it is nothing compared to the FEL. Hey the best part is, it will be a new tool in the arsenal. One way or another I can convice the wife it was a good idea. She hates the grass in the driveway, so she is all for this one. I have really been impressed by this tractor so far......it's small but unbelievably powerful.
/ 1301D box blade capability #7
The bucket on a loader will work well on the grass and take out the crown. not to good at moving gravel from side to side but is a killer on holes.
Just wanted to take the time to thank everyone for their input. After close to two weeks of trying to procure a used 48 in box blade, I gave up and purchased a new one from TSC. It's a Kingkutter. You guys were right on the money. My tractor had more than enough guts to rip up the driveway. The weeds and the center hump are gone. Everyone that has stopped over thought I had fresh gravel delivered. I have had this tractor for about a year and have to say I love it. It amazes me how little fuel it uses also. I thought about ripping up my neighbors driveway up while he was out of town, just to keep working it,but decided he might not appreciate it!! Thanks again everyone!
/ 1301D box blade capability #9
That sounds like me. Every time my neighbor goes off for the weekend, I sneak over and cut his grass. I wonder if he,s figured out who's doing it yet?
Eugene
/ 1301D box blade capability #10
There are lotsof ideas here!!!!!!!!!
but people seem to be very casual with this site!!!!!!!!!!!!!
Any body interested in a joint venture ?
I got some stuff to share
/ 1301D box blade capability #11
Is it a King Kutter XB series or a regular KingKutter? I have the XB for my Yanmar and also have 200 pounds of weight on the front. Ive never had a problem with pulling enough, even on our steep driveway. When I want to dig in more, i just put a few weights on the Boxblade and it sinks right in. I dont use the teeth mush since I wear them out pretty quick doing all sorts of work and they bounce on harder driveways making the job longer. Oh well, more seat time.:D:thumbsup: Boxblades are great for driveways, maintaining trails, digging and moving dirt, etc. Every time i use it, i am pleased with it and if it doesnt cut it, i have a few more implements that will get the job done. Have fun with your new Boxblade!
/ 1301D box blade capability #12
who is william, why did he dig up a 3 yearold post and what does that comment even mean?
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
3pt Hydraulic Log Splitter (A64127)
3pt Hydraulic Log...
White 6182 12R Planter (A66285)
White 6182 12R...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
