12v socket on tag
/ 12v socket on tag #1
farmhand96
Kubota b26
I have a 2006 Honda trx 250 ex sporttrax is it possible and how hard is it to hook up a twelve volt socket to my ATV so I can run a twelve volt compressor for whence and my friends go trail.riding
/ 12v socket on tag #2
Red to pos terminal, black to frame.
I would run an inline fuse on the red as close to the battery as possible. I would match the size of the wires to the wires that come with the 12volt device or the same size that comes with the in-line fuze.
Or, you could find a "key on" or "key on, engine on" wire coming out of the steering column and tie into one of them. I'd use a fuse as close to the power source as possible no matter how I hooked it up.
Get a good one; outdoor/water resistant.
/ 12v socket on tag
Thanks hey do u think I should upgrade the battery
/ 12v socket on tag #4
Nah,
I run a compressor from a factory outlet on my ATV, never had any problems. Its good for reinflating tires at 2 to 10 PSI.
It wouldn't run the smallest inverter tho, not enough amps.
/ 12v socket on tag
Well.I have to install one because it doesn't have one on it
(1) 7.2-16 TIRE W/ 6 LUG RIM (A64280)
(1) 7.2-16 TIRE W/...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
2018 LANDOLL 330 S/A  DROP DECK TRAILER (A59912)
2018 LANDOLL 330...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
UNUSED WOLVERINE LAND LEVELER (A64281)
UNUSED WOLVERINE...
iDrive TDS-2010H...
