Tires 1250 tires
/ 1250 tires #11
73jeep said:
I think your 1250 was replaced by 1433 model(size,hp,etc.). The R4 Ind. tire used for the rear on the 1433 was a 15 x 19.5 tire. Not sure the size of the front tire, but maybe someone here on the forum may have a 1433 with R4 tires & be able to help.
On a 1250 and 1260 there was 2 r4 tire options:
Front 25x8.50-14 Rear 15-19.5
or
Front 10-16.5 Rear 14.9-24
Try to match your front and rear tires to get a 0 - 5% lead.. That means the fronts will be turning 0 - 5% faster than the rears. Here is a formula to help calculate this.
(Front tire loaded radius/Rear tire loaded radius X axle ratio) -1 X 100 = % lead.
A tire dealer can give you the tire info and the axle ratio for a 1250 is 1:1.6077771. This means that the front axle spins 1.6077771 times for every 1 time of the rear axle.
Hope that helps.
/ 1250 tires
or
Where did you find that information. That is what I have been searching for. I would still need to change the wheels but it may come to that IF I can't live with the way it performs this spring.
Thanks 1250Man
rackoholic
/ 1250 tires #13
Interesting weekend, I was pulling some old stumps this W/E and my 1020 with turf tires just slipped. I got my old 2N with R4's on it and it pulled them with ease.
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A61307)
2008 Ford F-250...
Caterpillar 906M (A53317)
Caterpillar 906M...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
40' CONTAINER (A52706)
Coats 1055 Direct Drive Wheel Balancer Machine (A59230)
Coats 1055 Direct...
