Tires 1250 tires
/ 1250 tires #1
rackoholic
I was wondering if anyone has changed to the R4 tires on there 1250. I have a 4X4 with the turf tires and was thinking about upgrading to the R4's. I have not been able to find any that are the same size as the tires I am running, and with the 4X4 I will need to keep the rotating diameters the same as they are now, any help would be great.
Thanks rackoholic.
/ 1250 tires #2
Actually I don't believe you need to keep the rotating diameters the same as your turf tires.
BUT you do need to keep the front "lead factor" the same - or very close. That involves front & rear rolling circumferences and gear ratios. So - If you increas rear rolling circumference by xx% you should be OK if you also increase front by the same xx%.
/ 1250 tires
Thanks Fredex, but wouldn't your rolling circumference be the same as my rotating diameter?
/ 1250 tires #4
I think your 1250 was replaced by 1433 model(size,hp,etc.). The R4 Ind. tire used for the rear on the 1433 was a 15 x 19.5 tire. Not sure the size of the front tire, but maybe someone here on the forum may have a 1433 with R4 tires & be able to help.
/ 1250 tires
I guess either way I'm looking at replacing wheel and tires all the way around. That could get very pricey.
rackoholic
/ 1250 tires #6
The least expensive way to change the type of tires other than a salvage yard is to get your tractor dealer to order them though Whole Goods. The only draw back ordering them that way is that you would have to wait until a shipment of new tractors came in to get them.
/ 1250 tires
Is there a manufacturer that makes the R4 tires in the same size as the Bridgestone's that are on mine. I think they are 380D 20. I have only been able to find either the AG tire or the turf tire.
rackoholic
/ 1250 tires #8
I scanned my 1260 operator Instruction Book
maybe this info can help it also covers the 1240 and 1250
LUBRICATION & MAINTENANCE -59
WHEELS & TIRES
Examine wheels and tires periodically for correct inflation pressures, tight wheel bolts, and any physical dam age that may be a detriment to Tractor operation and operator safety. Correct condition prior to Tractor op eration.
Tire Inflation Pressures
FIG. 108: Maintaining correct tire pressure will help insure tire long life. If tires have deep scratches, cuts or punctures, the respective tire should be repaired or replaced by qualified personnel as soon as possible.
IMPORTANT: If necessary to replace any tire(s), en sure original tire size is used. This i par ticularly true on 4-WD models to ensure correct amount of front axle overspeed (or lead”) is maintained.
Wheel Bolt Torque
FIG. 109: Periodically check all wheel bolt torques. Correct bolt torques:
Front Wheel Bolts, 1 75 ft.-lbs. (102 N.m)
Rear Wheel Bolts, 2 120 ft.-lbs. (163 N.m)
Rear Wheel Center 1 20 ft.-lbs. (1 63 N.m)
to Rim Bolts, 3 (Ag. Tires Only)
a CAUTION: Correct wheel bolt torque must be maintained. Installation of front or mid-mounted implements (ex; loaders, mowers) impose in creased loads and require frequent checking of wheel bolts.
Front Wheel Alignment
FIG. 110: Correct “toe-in” dimensions of front wheels (A minus B) are as follows:
2-WD 0.08 to 0.16” (2-4 mm)
4-WD 0.08 to 0.24” (2-6 mm)
To adjust, loosen lock nuts, 1, and adjust tie rod length by turning turnbuckles, 2. Adjust each side evenly. Ball joints must move freely after lock nuts are tightened.
NO TE: Measure toe-in from tire center to tire center at a point haffway up on face of each tire.
TRACTOI
TYPE
TIRES
TIRE
LOCATION/SIZE
PRESSURE PSI (KPA)
MF 1240
2W0
AG Fronl—5.OO-15 F2 Rear—i1.2-24R1
PSI (KPA) 41(283) 17(118)
Turf Front—24 x 8.50-12 R3 Rear—355/800-20R3
PSI (KPA) 23(159) 14 (97)
MF 1240 4WD
AG
Front—7-14 Ri Rear—11.2-24R1
PSI (KPA) 26 (179) 17(118)
Turf
Front—27 x 8.50-15 Rear—355/800-20 R3
PSI (KPA) 23(159) 14(97)
MF 1250
2 WD
AG
Front—5.50-16 F2 Rear—12.4-24 Ri
PSI (KPA) 41(283) 14(97)
Turf
Front—24 x 8.50-12 R3 Rear—355/BOD-20R3
PSI (KPA) 23 (159) 14 (97)
MF 1250
4W0
AG
Front—7-16 Ri Rear—12.4-24 RI
PSI (KPA) 26(179) 14(97)
Turf
Front—212/80D-15 R3 Rear—355/80D-20 R3
PSI (KPA)23(159) 14(97)
MF 1260
4 WD
AG
Front—8-16 Ri Rear—13.6-24 Ri
Turf
Front—212/BOD-15 R3 Rear—355/800-20R3
/ 1250 tires #9
If you go to the Firestone(Bridgestone) website, & go under tires > agricultural > tirefinder > tiresize > 12.5 x 20. This is an R4 that might work on your current wheel size.
Its overall width is 12.7", overall diameter 40.0", & rolling circumference 121".
/ 1250 tires
Thanks 73jeep I'll check it out.
rackoholic
/ 1250 tires #11
On a 1250 and 1260 there was 2 r4 tire options:
Front 25x8.50-14 Rear 15-19.5
or
Front 10-16.5 Rear 14.9-24
Try to match your front and rear tires to get a 0 - 5% lead.. That means the fronts will be turning 0 - 5% faster than the rears. Here is a formula to help calculate this.
(Front tire loaded radius/Rear tire loaded radius X axle ratio) -1 X 100 = % lead.
A tire dealer can give you the tire info and the axle ratio for a 1250 is 1:1.6077771. This means that the front axle spins 1.6077771 times for every 1 time of the rear axle.
Hope that helps.
/ 1250 tires
or
Where did you find that information. That is what I have been searching for. I would still need to change the wheels but it may come to that IF I can't live with the way it performs this spring.
Thanks 1250Man
rackoholic
/ 1250 tires #13
Interesting weekend, I was pulling some old stumps this W/E and my 1020 with turf tires just slipped. I got my old 2N with R4's on it and it pulled them with ease.
RAIN FLO 1200 WATER WHEEL TRANSPLANTER (A63291)
RAIN FLO 1200...
159120 (A60430)
159120 (A60430)
John Deere 4040 Tractor (A64047)
John Deere 4040...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2004 Chevrolet Silverado 1500 4x4 Pickup Truck (A61573)
2004 Chevrolet...
