1240 water pump
/ 1240 water pump #1
westfallser
massey ferguson 1240
I have a MF 1240 in need of a water pump. Just wondering if anyone has a part # or a website to purchase. Dealer is asking about 300.00 might be the way to go but just wondering if anyone had any suggestion.
/ 1240 water pump #2
You can get the parts to rebuild it from the dealer. I needed the shaft with the bearings, the seal, the gasket & the impeller. I spent about $100 to rebuild mine (1250 same pump) about 2 weeks ago.
/ 1240 water pump
Thanks for the advice. Just wondering if you had to remove the radiator.
/ 1240 water pump #5
No, but it is a tight fit. Get Yourself a piece of cardboard to protect the radiator fins & Your hands. You can remove the Radiator mounting bolts and move it forward slightly while leaving the hoses attached. You can get a general idea of what You need to do by watching this video :
Step by Step Water Pump Rebuild For John Deere New Generation Tractor :: Tired Iron Videos
Good luck!!
/ 1240 water pump #6
Yeah, rebuilding would be the best option as far as cost is concerned or trying to find one that will cross from another generick mfg. Here's the agco site where you can order just about anything new you might need for your tractor or for that matter any MF, but agco thinks quite a bit of there parts. You'll find out when you get a price quote from a dealer.
AGCO Parts Books
/ 1240 water pump
Thanks for all the help. I got the water pump in yesterday put it in today. Came out easier than in. I did have to take off the radiator but all is secure. My question is how much tension to put on the belt.
