12 VOLT DASH HEATERS?
/ 12 VOLT DASH HEATERS? #1
escavader
western maine
bx-23 ,
HI
I lost the heater core in my old ford plow truck yesterday.I saw one of those 12 volt plug into the lighter heaters in wal mart,has any one tryed one?I only want it to keep the windshield thawed,also ive been planning on a cab and blower for my kubota,mabey could use it there when i get rid of the truck.Although im mechanically inclined,the core looks like a pain in the ... to get to,and i really dont want to shell out alot of money for it.So i bypassed it,but i have no defroster.Will it work?
ALAN
/ 12 VOLT DASH HEATERS? #2
I was considering on or these also. I would be good to hear from someone that has used one.
I have not repalced the heater core on a full size ford. The heater core on a small size ford truck is not very difficult to replace. Some car heater cores are a pain to replace. For example the Ford Taurus shop manual indicates it takes 12 hours of shop labor and the dash needs to be removed. On the 88 Ford ranger there was easy access with access below the dash.
When a heater core goes bad it is either blocked or leaking. If it is blocked try flushing it with a garden hose. Loss of heat is could also be an issue with the coolant flow due to other problems in the engine or the vent controls.
Just talked to one of my mechanic friends.He said a heater core for my 73 is around 30 bucks.He also said if im not gonna run it on the road again,he would cut out the spot where it goes instead of ripping every thing apart.I still want to know if the 12 volt ones work.Considering his labor for helping me,i still be ahead if the 12 volt thing works,and can use it in my tractor cab
ALAN
/ 12 VOLT DASH HEATERS? #4
I doubt that it would provide enough heat to defrost the windshield. The cigarette lighter outlet is only rated at about 16 amps (depending on manufacturer). This would be about 224 watts. That's about 1/6 the power of a room electric heater.
/ 12 VOLT DASH HEATERS? #5
That's true, but. Don't forget the air volume inside the cab of a truck is what, 40 times smaller than a small room in a house. I'm not saying it would cook you out of the cab but it would probably work for what he wants to use it for.
/ 12 VOLT DASH HEATERS? #7
Alan,
I installed an electric heater on the BX cab before I installed the heater via the engine. Could not get enough heat to warm up the small BX Sims cab. Unlikely it would work on a windshield.:(
/ 12 VOLT DASH HEATERS? #8
My opinion, won't work very well. Just not enough heat there. The cigarette plug does not carry that many amps. And any old truck leaks enough air to dilute a lot of the air.
Again it is just my opionion.
murph
/ 12 VOLT DASH HEATERS? #9
You have to figure that most vehicle air conditioners are 18,000 to 24,000 btus which is enough to do a small house. So I believe their heaters are about the same btus. Moving vehicles are not sealed and are purposely vented requiring large heating/cooling systems.
THANKS, I guess i gotta heater core to install
ALAN
/ 12 VOLT DASH HEATERS? #11
Good point. I believe that car air conditioner run about 20,000 BTU. I don't know what the heater runs, but probably more. The electric heater would be about 760 BTU (3.412 * 224). That's less than 1/20 of what cars use. Cars have very little insulation and need to be heated very quickly generally. I think this might be an OK one person heater. If you like give it a try. I would fix the car heater.
/ 12 VOLT DASH HEATERS? #12
Look at it this way, a 70's vintage Ford truck is easy to change the heater core in. I did my 77 years ago and it was a breaze. Sure beats doing modern day cars and trucks.
Good ,since you volunteered:D :D GIVE ME THE LOWDOWN!
MY book says i got to take apart the area where the heater levers are,unhook the cables do this do that....What really do i got to do to get at the thing?I took a couple screws out from the plastic vent box in front of it,but cant figure out how to take it out,somethings still holding.Can you give me a quick idea?
You seem to be bailing me out alot lately:D :D :D Ill buy you a 12 pack if you want to come to MAINE and pick it up:D
ALAN
/ 12 VOLT DASH HEATERS? #14
I know I'm a little late joining this conversation, but I have practical experience with one of those 12v dash heaters.
I have a mini-van that either needs a new fan or a fuseable link, I believe, and both require pulling the dash out, something I have no interest in doing.
I live in So-Cal at about 3000 of elevation, enough to get a little snow twice a year, but with plenty of cold (for us) mornings.
It takes a few minutes for my 12v dash heater to clear a 10" circle, which is good enough to drive slowly to the main road.
The rest of the windshield clears up eventually, usually with the help of paper napkins.
As for keeping me warm, I wear a heavy jacket & gloves, the heater puts out 300w, I believe.
/ 12 VOLT DASH HEATERS? #15
I had one, It never really helped the windshield defrost. Then the switch failed.
It's in the land fill now.. Done with that crap. Chinese junk!
/ 12 VOLT DASH HEATERS? #16
14 year old thread revival....
That's about how long it took my 12V dash heater to defrost my windshield.
2024 John Deere 8R 370 Tractor (A63109)
2024 John Deere 8R...
Atlas Copco Air Compressor & Air Dryer (A62613)
Atlas Copco Air...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2016 PETERBILT 579 (A63569)
2016 PETERBILT 579...
