12 ft Wheel disk...Can I pull it ???
/ 12 ft Wheel disk...Can I pull it ??? #1
N401pf
St.Louis, Mo
JD 1530
Greetings
I own a John Deere 1530 with a total engine HP of 45 and a drawbar HP of 38.. Now
I just got a deal on a JD 12 Wheel Disk Will I be able to pull this much? I have been told NO looking for other opinions
Thanks
Scott
/ 12 ft Wheel disk...Can I pull it ??? #2
It all depends on your local conditions and what you want to do with it.:)
If you have weight on it a good angle and working in nice black dirt be prepared to sit in one spot.
/ 12 ft Wheel disk...Can I pull it ??? #3
As long as you keep the wheels down. :D
7 to 8' is typically the functional limit .
/ 12 ft Wheel disk...Can I pull it ??? #4
You probably could pull a light duty finishing disc on level ground (maybe). A heavy 12' double offset or single offset disc would be a load in transport position.
/ 12 ft Wheel disk...Can I pull it ??? #5
Greetings
Thanks
Scott
I'm able to pull my 13-ft Minneapolis Moline KS1300 wheel disc in dry soil conditions with my 2008 Mahindra 5525 (55 hp engine, 45 hp pto). I cut it down to about 8-ft wide so I can handle soft soil and it works fine.
Good luck.
/ 12 ft Wheel disk...Can I pull it ??? #6
I doubt you'd get much use at all out of a 12' disc behind that tractor. A nice heavy 6-7' 3pt disc would be ideally suited to a 1530.
/ 12 ft Wheel disk...Can I pull it ??? #7
I agree.
It seems like cutting out the tractor tracks by 6-12" on each side about catches it for most small tractors.
We had Ford Flex-I-Hitch 6.5' and 7.5' disks for our Ford 801 tractors and when cutting to the axle with a drag in 3rd gear they got a work out.
/ 12 ft Wheel disk...Can I pull it ??? #8
If you got a good deal try trading it for an 8' unit as your tractor will be much happier with that size.
/ 12 ft Wheel disk...Can I pull it ??? #9
I have a 13 foot Case tandem disk for my Kubota L5740 and it is about all I can handle. I also have a 6.5' 3 point that I bought for my L3710 before trading it on the larger tractor. The small disk was rights for the small tractor - it would never have pulled the tandem wheel disk. I have about 1,000 pounds extra weight on the tandem so it cuts in really good but more power would be nice.
Hey Guy's I finally found a 8ft RWA with 19 new baldes on it, good cylinder for 1000.00. Any suggestions on where to pickup up some replacement scraper blades and bracket's??? Thanks 3Fa3m93H55Ld5Ed5K6d1tc027495c37fc1f4c[1].jpg3K13Le3lf5F45H25Mcd1tf1cdddcdfc8b1e5d[2].jpg3K13pf3H25Gd5K25Mfd1t9c93a7c481d615a3[1].jpg
/ 12 ft Wheel disk...Can I pull it ??? #11
john deere dealership
/ 12 ft Wheel disk...Can I pull it ??? #12
Nice looking disc.
Check the JD website for parts info.
Otherwise, fabricate them yourself.
Good luck.
Dealer can get them out of Dallas, 39.13 each Ouch, Looking for other options
/ 12 ft Wheel disk...Can I pull it ??? #14
They last a long time though. Fix it up right and it will last you a lifetime.
/ 12 ft Wheel disk...Can I pull it ??? #15
Wish you were on the other side of the State, I'd talk you outta your 12'.
/ 12 ft Wheel disk...Can I pull it ??? #16
I have bought parts for tillage equipment from Shoups and have been very satisfied. Here is a link to John Deere disc scraper parts: Disc, Vertical Tillage - Shoup.
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
2009 Featherlite Race Car Hauler Enclosed Trailer (A62613)
2009 Featherlite...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
