1100 RTV/Mattracks BEWARE!
/ 1100 RTV/Mattracks BEWARE! #1
ttowne66
Mannsville, NY (east of Lake Ontario)
Kubota L4330 HST
Guys
Just a notice. We recently bought a RTV 1100 for our snowmobile club and we are having issues with the driver side rear track rotating up and hitting the mattracks guard, stalling the track then getting stuck. Second issue was that the rear leafs were getting severe spring wrap which caused the driveshaft leading to the front to hit/rub on one of the motor bracksts. We are working with Mattracks right now and they are sending us different length components for their system to limit the track systems rotation on the driver side. We had to work with a local leaf spring house to add two extra leaf springs to each rear stack. This addressed two issues. 1) gave a 5/8 suspension lift which kept the driveshaft from rubbing by eliminating the spring wrap. If you currently own an 1100 with Mattracks I strongly suggest you address these issues or 1) you'll be getting stuck a lot 2) You'll be having issues where the driveshaft rubs. Just put a 5in log or something in front of the rear driver side track and go forward until the system rotates up to go over it and you'll see the tracks hit the guard that goes over the area where the radiator is. This is when the track stops rotating. I understand there is no issue with the 900 because the radiator must be in a different location which doesn't interfere with the tracks.
Also, I wish this thing had some more ponies. Seems very sluggish. I have been reading quite a lot here and will make sure the dealership put SUDT in instead of UDT. I'll be checking the spark arrestor for build-up as well. Strange because the unit slows down to a creep but the motor doesn't drop in RPM. This unit has the hand throttle and you can get a couple hundred more rpm this way but it goes unused as the tranny seems to be the limiting issue! Perhaps a pop off bypass set wrong or something? Kind of lost here so if anyone has some suggestions here it would be very welcome. Thanks.
Tom
/ 1100 RTV/Mattracks BEWARE! #2
I have a 900 with Soucy tracks and I have not seen any of the issues that you are seeing. However I do not groom. I have trails thru my sugarbush and I have been dragging a wooden pallet to knock down the center. I run in Med range most of the time with the differ locked and hardly ever use 4x4. If I have to climb a small hill that has a lot of snow in the trail then I will shift to low and go to 4x4.
How much do you tracks weight each and how much plastic in their construction?
Deerlope
Aside from the rubber wheels it is all aluminum construction. We had our local mechanic do the install and he is extremely complete with everything he does but I'll have the track tension double checked. Yea, apparently the 900 does not have the massive radiator behind the driver door which has caused Mattracks to make modifications. Regardless.....I would have a look at the front driveshaft (under the box right near the firewall at the engine) to make sure the shaft is not rubbing on one of the brackets there. When the front of the rear track system encounters a bump the force being so far from the centerline of the axle causes severe spring wrap which does not allow the travel limiting bump stop to function properly. This allows the suspension to overtravel in compression stroke. This can cause the front wheel drive shaft to rub. Something to look for!
/ 1100 RTV/Mattracks BEWARE! #4
Can this problem occur regardless of who's tracks are being used? I will check this out tomorrow.
deerlope
More than likely you will have the same issue on 1100 with soucys or others unless they have a way to limit the lifting of the front of the rear track when encontering an obstacle or bump. I just got confirmation that the third solution Mattracks has sent to us did not work. They kept sending us longer length links to attach to the torsion levers they include with their kit. Our guys in the club have 3-4 full days work on this unit trying to make mattracks solutions work to no avail. They just called me and said they fabricated up a solution of their own which ended up with an adjustment bolt to allow the tracks to lift up just below the point of making contact with the sheild covering the box for the radiator.
After all is said and done, we are obviously not impressed with Mattracks engineering department at the current moment. They were basically guessing on each new resolution to this issue with no solution. We kept getting different length links from 3 to 6in long. After further analysis the guys said working with the mattracks torsion set up the link would have nearly needed to be scraping on the ground in order to keep the track from rubbing. They will need to come up with a solution similar to ours or they will be getting calls from every owner of this combination. I am sure they will eventually come up with a solution but they will still have to address the issue of the spring wrap with extra leafs for the spring pack included with their kit.
/ 1100 RTV/Mattracks BEWARE! #6
This is the 1st problem I have heard of with tracks and the rtv.
This problem may be unique to this rtv's conditions and use.
ttowne66 have you heard of this happening to others?
Can you post pics of yours?
Any links to similar problems?
/ 1100 RTV/Mattracks BEWARE! #7
When I first saw the 1100 I wondered how they were going to address the radiator with tracks. Can't say I knew it was going to be a problem but did think it was an issue that would have to be dealt with. I don't like that you need 2 extra springs in the rear. The travel is next to nothing in stock form and the ride is stiff enough already. I hope you get this resolved.
skipholiday
It is likely that owners of this combination 1100/mattracks may not notice an issue till they encounter an obstacle large enough to cause the track to rub. The issue is most likely to be found when traveling at slow speed and in snow. I'll try to explain the sequence where we noticed it the earliest. Lets say you are on a snow covered trail and approaching a plowed road. At the moment you proceed off the trail and on to the road the front of the machine tips downward and the tracks drop down on to the road. At this point the front of the machine might be a foot or so below the rear tracks. This angle will cause the rear driver side track to contact the mattracks supplied guard to cover the housing for the radiator. This is where I believe the speed issue comes in, since you are just barely moving at this point there is no momentum to carry the machine thru the extra load of having the track contact the guard. What happens then is that now not only does the machine loose this track to move the forward but the remaining drive tracks are now trying to pull this locked track. What happens is the passenger side rear track and either of the front tracks spin out and you are stuck. I can also see this happening while traveling over a log or other obstacle at slow speed. It is likely that if you are traveling fast enough the momentum would carry you thru this locked position but you'll still be rubbing the track on the guard. Hope I have explained this well enough.
/ 1100 RTV/Mattracks BEWARE! #10
I do know that the Soucy tracks for the 1100 had to be made shorter in length because of the radiator issue. The rear track for the 900 is 46" long and I think the 1100 is 38". I will say this and that is I am not having any issues with the Soucy tracks and the RTV 900.
When I get time I will take pictures of where the driveshaft was rubbing, the extra leafs and the guard area where the track hits. I will not be able to actually show the track hitting now because apparently the guys have resolved the issue. I will take a photo showing the tracks going up a bump or ramp to show the resolution of the issue though.
/ 1100 RTV/Mattracks BEWARE! #12
I would not disclose to Mattracks what was done unless they are willing to compensate your club in some way.
Hey guys
I am down at the folks while all this is going on but I got word that the guys took the 1100 out and everything woorked out great. I'll send out some pics in a few days.
/ 1100 RTV/Mattracks BEWARE! #15
I would not post them on here. You would be surprised at the number of companys' the surf these web site for ideas. Then say it is their design and get a patent and sell for big bucks.See if Mattracks wants to make a contribution to your grooming fund then post them.
Deerlope
I hear what you are saying. Our guys that worked on the unit would likely agree with you 100% as they spent a bunch of hours analyzing and sorting out everything I outlined previously. Personally I really only have an issue with the fact that Mattracks did the following
1) Showed us a picture of the 1100 with tracks on it and said that they had figured out how to work around the radiator housing.
2) Then sold us the track set without really analyzing the situation. This drive shaft interference is real and it is not too difficult to see what is causing it.
3) Basically guessing on lengths of components to resolve the problem and Ultimately never came up with a solution. Apparently our fix has no similarity to Mattracks torsion set-up.
I am sure of one thing. If they wish to continue selling tracks for this particular unit they will have to address the problems with their current system. Aside from the application design problems I think the tracks themselves are really sweet and hope they serve us well. I'll keep you updated!
Tom
/ 1100 RTV/Mattracks BEWARE! #17
Having to redsign the track set up has got to be worth something to the Grooming club. Diesel fuel is all most 4 bucks a gallon. When I bought my track I had to go thru a Kubota dealer because he was their dealer. I went and talked with him and I said hey I will be the first and only one in this area to have a set of them and it will only help your business. I want your best price and I will only ask once. He knocked 1K off the retail price. I took a few pics of it in deep snow and sent them to him.
Soucy has a test track at the manufacturing plant. The rep told me they also test the tanks & APC's there too. I had to wait for mine to be made because of some new up dates. I frimly beleive that nothing leaves their plant until it is tested and proven. Last year when I did not have the tracks I used 5-7 gals of fuel all winter. I have already used 10 gal this winter.
/ 1100 RTV/Mattracks BEWARE! #18
I have a set of Soucy tracks inbound for the 1100. They modified the rear tracks to prevent this. The rear tracks are shorter than thier units for the 900 I believe.
/ 1100 RTV/Mattracks BEWARE! #19
Pat; you are correct they are shorter. That is what the company rep told me they had to do because of the radiator.
/ 1100 RTV/Mattracks BEWARE! #20
TTowne66, Thanks for all the good info and the problems that you encounter with the RTV 1100 and the Mattracks that you put on it. I am sure that you will get some calls/emails as to what was done to remedy the problems.
