3-Point Hitch 110 TLB-Installing/Removing 3PH
/ 110 TLB-Installing/Removing 3PH #1
RaytheOne
KY
JD 323D
Just looking for advice or feedback on how involved the 3PH installation is? Since the BH is on, I'm trying to get some projects done with it before I make the switch to 3PH operation. Right now, everything looks like a hole to be dug, :D but I need to make room to take the backhoe off and put on some other attachments.
Most important is getting my splitter hooked up.
Thanks!
/ 110 TLB-Installing/Removing 3PH #2
Usually it is a five to ten minute job for me to remove the hoe since I have a cab on mine. Installing the three point hitch takes another five minutes.
When I remove the hoe I do block it up with wood blocks incase the cylinders leak down some. I also clean and grease the large upper pins to make them slide in easier.
Once you do it a couple of times it is a simple thing to do.
/ 110 TLB-Installing/Removing 3PH #3
Removing and re-attaching the hoe takes less time than hooking up the 3pt. Dropping the hoe takes 2 minutes and it's about the same to pick it up again.
Because I have the top n tilt for my 110; routing (wrestling) the hyd hoses and the cylinders is more of a challange than the hoe - IMO.
AKfish
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2017 Mack Semi (A64047)
2017 Mack Semi...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2017 Nissan Juke SUV (A61574)
2017 Nissan Juke...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
John Deere 995 (A64126)
John Deere 995...
