110 TLB Box Blade Operation?
   / 110 TLB Box Blade Operation? #1
threepiece
Farmington, Mi
Kubota L3400 John Deere110 TLB Wheelhorse 520H
Hello fellows, first post here. I will thank you for the information that I am looking for now because I am certain I will get it from here. I have searched the Internet for the last two days and called several dealers but no one can give me a definite answer.
I am looking to buy a 110 but before I do I must know weather or not a fully, remotely controlled box blade can be fitted to it.
My understanding is a full remote controlled box blade has three separate functions. What I would like to know is: are these functions handled by the same system that controls the backhoe or are separate auxiliary remotes required for this. Thanks again!
   / 110 TLB Box Blade Operation? #2
All the backhoe controls come off with the hoe, you will need separate valve work to operate the box blade cylinders
   / 110 TLB Box Blade Operation? #3
:welcome: to TBN
A JD box blade ?? and if so what is the model number?
   / 110 TLB Box Blade Operation? #4
Boy , I am not sure I am following you. I always thought a box blade was three point hitch and pretty station area. Most have rip teeth that you can manually adjust their depth and you can push/blade backward. The are great for grading the drive way. There are rear blades that you can adjust the angle on or turn them around ba coward to push/blade backwards. Some of these rear blades you adjust manually. Some have a hydraulic cylinder on them and you can adjust them and never get off the tractor. The same hydraulic that run the backhoe. Please elaborate on what a full remote controlled box blade is.
   / 110 TLB Box Blade Operation? #5
He is talking about an industrial quality box blade that has hydraulic actuated rippers. Typically the tractors that have these box blades also have a top & tilt system for the 3pt hitch, (hydraulic top link and hydraulic side link)thus the 3 rear remotes required.
   / 110 TLB Box Blade Operation? #6
Thanks for the explanation, I have mostly an ag background. I learned something from this thread/post.
Well there it is. Quite obvious really. I wonder why I had so much trouble, I probably could have figured it out if I looked at a picture a bit longer.
I guess I will look into the possibility of adding a controll system, my understanding is that adding a full remote hydraulic system is not feasible on a 110 TLB.
   / 110 TLB Box Blade Operation? #8
I would think it's doable but a lot of work/trouble. Would need to start by building a 3 point hitch for the tractor and then connect to the hydraulics the same way the backhoe does. I have seen one of these just like you are wanting but it was on an older industrial tractor. The whole 3 point and box blade was removeable and pinned to the tractor just like the hoe. It had it's own valve/controls and connected to the tractor hydraulics just like the hoe. No reason you couldn't use the tractor's hydraulic system.
If you do that and build your own go with a 4 spool valve so you get up/down, tilt right/left, tilt front/back, and hydraulic rippers. I have this setup on my JCB and it works great.
   / 110 TLB Box Blade Operation? #9
I have a jd box blade bb1284 with a new 3pt top & tilt, I might sell. I will send you a pm
   / 110 TLB Box Blade Operation? #10
You should have the 3pt lift arms and position control on the tractor as is. Sounds like you may need the rest of the 3pt hitch, (lift rods, drag links, anti sway links) as well as getting a 3 valve rear remote system set up on it, and a top & tilt set.
All which can and has been done many times.
None of this is cheap how ever. :eek:
1995 ADVA Concrete Mixer TRUCK (A56858)
1995 ADVA Concrete...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
(3) FUEL TANKS (A52708)
(3) FUEL TANKS...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
