$11,000 Water Bill
   / $11,000 Water Bill #221
I believe that pvc piping is not designed for pressure ,,, you may have a case against the builder. I wonder if your local plumbing and/or building inspector should have signed off on the plumbing.
No disrespect... but a little friendly advice... you ought to read through the thread and get up to speed before responding.
   / $11,000 Water Bill #222
I had a house with poly supply
Currently I work and live in the city of Cincinnati with ductile iron main and copper supply lines
When I lived in Cincinnati I had a lead pipe from meter to house, which was replaced with copper. Not much green pipe in that old city.
   / $11,000 Water Bill #223
As a home inspector I have been involved in a half dozen water line breaks under homes as a result of impacts on the plastic water lines during construction. I have several cameras that I use to locate the source of the leak. Recently I discover a 10 year old leak that I guestimate was spraying about 5 gal per min into the crushed rock weeping tile and eventually running down the sewer line via the sump. If I did my math correctly that's about 5.5 million gallons. Lucky for the sellers the leak was before the meter. The wight poly line was like a rock penetration. 20170919_135403.jpg20170911_113300.jpg20150402_150325.jpg
   / $11,000 Water Bill #224
No 11k water bill for me yet but I did get a 2-month $950 bill with average daily use of 500 gpd which includes sewer treatment based on gallons used.
Turns out a defective sprinkler valve was leaking about 15 gallons per hour day in and day out.
My typical 2 month bill is about $425 based on 110 gpd including sewer treatment.
On the farm water/sewer is free as water is deeded spring water gravity fed at 65 psi… quite a savings over the decades and so good it was bottled for almost a hundred years.
   / $11,000 Water Bill #225
I
Its Déjà vu all over again...
   / $11,000 Water Bill #226
   / $11,000 Water Bill #227
Wow!. My monthly usage is around 3500 gallons. Typical bill is 34.00 without sewer hookup. Didn't realize we have it so good in middle TN.
   / $11,000 Water Bill #228
In my experience it's the sewer/wastewater fee that's the killer, not the water. Luckily I'm on a well/septic now so don't have to deal with that (hopefully ever again!)
   / $11,000 Water Bill #229
Yes, I know that at least two other leaks occurred at joints. I don't think those leaks were nearly as big.
This is on the builder, get an attorney. No way would you have multiple leaks on a line done properly? No way.
   / $11,000 Water Bill #230
Oh I just realized how old this thread is. Lol
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53473)
2016 KBH...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2015 WESTERN STAR 4900 (A53843)
2015 WESTERN STAR...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
