$11,000 Water Bill
   / $11,000 Water Bill #221
I believe that pvc piping is not designed for pressure ,,, you may have a case against the builder. I wonder if your local plumbing and/or building inspector should have signed off on the plumbing.
No disrespect... but a little friendly advice... you ought to read through the thread and get up to speed before responding.
   / $11,000 Water Bill #222
I had a house with poly supply
Currently I work and live in the city of Cincinnati with ductile iron main and copper supply lines
When I lived in Cincinnati I had a lead pipe from meter to house, which was replaced with copper. Not much green pipe in that old city.
   / $11,000 Water Bill #223
As a home inspector I have been involved in a half dozen water line breaks under homes as a result of impacts on the plastic water lines during construction. I have several cameras that I use to locate the source of the leak. Recently I discover a 10 year old leak that I guestimate was spraying about 5 gal per min into the crushed rock weeping tile and eventually running down the sewer line via the sump. If I did my math correctly that's about 5.5 million gallons. Lucky for the sellers the leak was before the meter. The wight poly line was like a rock penetration. 20170919_135403.jpg20170911_113300.jpg20150402_150325.jpg
   / $11,000 Water Bill #224
No 11k water bill for me yet but I did get a 2-month $950 bill with average daily use of 500 gpd which includes sewer treatment based on gallons used.
Turns out a defective sprinkler valve was leaking about 15 gallons per hour day in and day out.
My typical 2 month bill is about $425 based on 110 gpd including sewer treatment.
On the farm water/sewer is free as water is deeded spring water gravity fed at 65 psi… quite a savings over the decades and so good it was bottled for almost a hundred years.
   / $11,000 Water Bill #225
I
Its Déjà vu all over again...
   / $11,000 Water Bill #226
   / $11,000 Water Bill #227
Wow!. My monthly usage is around 3500 gallons. Typical bill is 34.00 without sewer hookup. Didn't realize we have it so good in middle TN.
   / $11,000 Water Bill #228
In my experience it's the sewer/wastewater fee that's the killer, not the water. Luckily I'm on a well/septic now so don't have to deal with that (hopefully ever again!)
   / $11,000 Water Bill #229
Yes, I know that at least two other leaks occurred at joints. I don't think those leaks were nearly as big.
This is on the builder, get an attorney. No way would you have multiple leaks on a line done properly? No way.
   / $11,000 Water Bill #230
Oh I just realized how old this thread is. Lol
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
